Old 09-04-2012, 08:18 AM
cubs-n-bxrs's Avatar
I also did the command 18 swap in my 682 and added full hydraulics. Those command motors run real nice and have a real sweet sound to them with dual exhaust set up.
Old 09-04-2012, 04:01 PM
My 582 has a CH18 in it, also. I made a 2 into 1 header. It sounds cool but is deafening from in front of the tractor. It will probably be removed and a muffler installed before it goes to another plow day.
Video 1
Video 2
Old 09-04-2012, 05:11 PM
Video 1
Video 2
Matt
That sounds AWESOME! Ear plugs!
Old 09-04-2012, 07:25 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Thanks for the info Wally. Did not know about the spacers and I will have to scrounge up some kind of wiring harness as there isn't one in the 582 now. I actually have the shaft coupler piece you mentioned off of a 1806 so that will work perfectly. Working on the grandson's 1200 puller for now so the 582 project will have to wait a bit.
Joe
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 09-05-2012, 11:21 PM
wally67's Avatar
wally67 wally67 is offline
Hey Matt that exhaust is pretty loud I might have to go with the stock style muffler for now. No new updates as of now I have been working on trying to get my house washed and painted. My luck would take the only week off of work this summer to get this done where there is rain in the forcast almost every day.
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 09-27-2012, 08:34 PM
wally67's Avatar
I finally had a chance to get some more done on this project this week. as of right now ive had it running and driving but pulled the muffler off to modify and paint it. I dont have any pictures of it all together but I do have some more detailed picks of the motor plate and the clutch driver spacers. The spacer thats closest to the flywheel I had 3/16" cut off one side so it would pilot into the back side of the other spacer so every thing centers up. On the motor plate all I had to do was move the rear bolt holes 3/4" forward of the rear slots and then drilled to new front ones.
Old 09-27-2012, 09:38 PM
Vince_o Vince_o is offline
When I put the command in Dannys 482 with a 124 rear, all I had to do was put the drive couplier in from MWSC and get a longer clutch arm.
Old 09-27-2012, 09:47 PM
wally67's Avatar
hey vince are you using the front pto
Old 09-27-2012, 10:03 PM
Nice work! Thanks for the pics.
Old 09-28-2012, 08:28 PM
wally67's Avatar
Here are a few more pictures of the install .I have also installed a super steer front axle out of a 1541 (not in pics).
