Old 09-06-2012, 09:58 AM
Fred's 123 Fred's 123 is offline
Engine's here. What should I check before install? Worth pulling the head and oil pan, to clean both?
Old 09-06-2012, 12:03 PM
PaulS's Avatar
PaulS PaulS is offline
If the engine is a used engine I would absolutely pull the head and oil pan just to see that all is clean and clear to operate. Even if an engine is new and never used I would at least pull the pan to clean any metal shavings/bits that may be there.
Old 09-07-2012, 06:07 PM
Cool. As I suspected. I figure I'll open up the new used engine, as well as remove my old engine this weekend. Order gaskets, etc. this week, and do the install next weekend.
Old 09-08-2012, 08:04 PM
Some differences between the new block and the old one. The "old" block is in fact not original to this Cub, but it's been in there the last 30 - 40 years.
1. Old engine has a chamfered bore at the carburetor interface.
Old:
New:
2. Old engine has dipstick on left side (integral with timing gear cover), new engine has it on the right. New dipstick tube interferes with generator mount and muffler. I'm assuming I need to find a blockoff plate for that right-side dipstick assembly, and reuse my cast timing gear cover with integral dipstick.
New:
3. Old engine has an extra gear in the crankcase, which I've been told is a counter-rotating balancing gear. The old man who installed this engine in this Cub many years ago told me this was supposed to vibrate less than the original engine, although he never noticed any difference himself.
Old:
New:
4. New engine has an extra hole into the crank case, below the carb. Presumably for a breather / PCV setup. I need to find the appropriate blockoff plate.
If anyone knows the numbers or source for the various block-off plates, I'd be very happy. Other items are:
5. New flywheel cover is larger than other, and contains a gear to interface with a gear/solenoid starter. I will swap for the old.
6. I need a new PTO bearing. This is an oddity to me, with the inner race extending way past the outer race on one face.
Old 09-08-2012, 09:42 PM
samiam44 samiam44 is offline
Humm.. what's the serial number on the new one?
You might want to pull the points off and replace the aluminum timing pin with the replacement kohler steel (if needed). Then set the points...
Easier done when out of the tractor.
Michael
Old 09-08-2012, 10:22 PM
s/n 4054213
I just talked to the old man who owned this tractor from new until last year. He still has the ORIGINAL motor out of this old Cub! He said it was actually a functional motor when he pulled it out, but the valve guides were worn, which was causing problems with carbon buildup, valve cooling, and valve sticking. He said that with a new set of valve guides, the original motor would be ready to go.
So, now I have a choice to make... new valve guides on the original motor, or find all the blockoff plates, dipstick tubes, etc., to make this new motor work? Time is of the essence... I really do not have time to be spending on this thing right now!
Old 09-09-2012, 07:40 AM
dag1450 dag1450 is offline
Freds 123, It sounds to me that you are in the landscape line of work,maybe you should rethink the tractors you are using for your work.I'm not sure 40 year old engines are what you need to be worring about when you are trying to run a business that already is stressful enough. I too am a cub cadet nut and own 5 tractors and about 10 attachments ,they are fun for a hobby but running a business with them ,i don't know? Dave
Old 09-10-2012, 10:12 PM
Nope... I'm just a homeowner / hobbyist. That said, I just bought a 240 year old house that's 5500 sq.ft. on a large property, with 4 acres of manicured lawn space. We are beyond busy with repairs, modifications, rennovations, etc.
I have a new John Deere 757 ZTrak mower with a 60" deck for mowing, and a recently-borrowed John Deere 750 utility tractor with front end loader, but this Cub sees more use than either of them, being my primary machine for pulling the fertilizer and seed spreader, weed sprayer, utility trailer, snow plow, snow blower, and an old 48" mower I use for brush hogging the "rough" areas. In the the next two weeks I need to aerate and seed, and both of those implements are too small to pull behind the JD 750, especially the tow-behind broadcast seeder which I need to be able to turn off and on from the drivers seat... I need my Cub.
That said, I think you're right... I need to plan to replace the Cub with something newer and more reliable. Problem is, I did not address this earlier, and now I'm in a pinch. Maybe I should post a new thread, to decide the fate of the Cub, and what to replace it with.
Old 09-11-2012, 07:10 AM
Sounds like a neat place u have there ,8 yrs ago i bought a 150+ yr old farm house in Doylestown pa (north of willow grove on the pa turn pike) and decided the house was just to far gone so we tore it down and built a new one.I am mowing 3 acres so i picked up a kubota with all the bells and whisles,but you know what, after a yr with that i had enough ,i sold that and picked up 3 cub cadet supers all with 60 inch decks and other goodies. Now i feel right at HOME and have one for each job.2072 mowing,982 blowing,1572 is going to snow plow when i get it back together. the 127 pulls trailers and carts and the 1450 is unemployed right now. Good luck with your tractors. Dave
Old 09-11-2012, 08:43 AM
Thanks, dag. I grew up in D-town, and almost certainly delivered newspapers to your old house, if it was in the boro. I don't think there's a house in that boro I can't name from a picture.
Based on the recommendation of a friend who knows how busy I am, I'm going to try to find a mechanic to rebuild and set up one of these three engines for me. I think the best candidate is the original motor out of this cub, pulled from the tractor around 1981 and stored in a friend's attic. Maybe putting the original motor back will finally make this machine happy and put the tractor gods at ease.
Now, how do I find a good Kohler mechanic?
New thread started at: http://www.onlycubcadets.net/forum/s...ad.php?t=20091
