Old 08-22-2012, 08:46 AM
TommyK's Avatar
TommyK TommyK is offline
Wish I caught this before. Looks like there's a reason you can't shut off your pto. There are no pto springs in it. Looks like the previous owner took the pto apart and put it back together w/out springs, so even if you adjust the turnbuckle and replace the fiber button, it's not going to disengage. I think you need to rebuild your pto. Check the service manual and double check your pto. You can get a rebuild kit from Chris also. Sorry, but i think your fix just got a little more $$$.
Old 08-23-2012, 08:40 AM
ab147's Avatar
ab147 ab147 is offline
"The first belt I bought was from a cub cadet dealer I read on here somewhere that they are better...but it was too long and they we closed on sunday soooo off to Tractor supply. But thanks for the advice
Reply With Quote"
Don't get belts from tractor supply. I've been there. their belts may be good for different applications but not on a cub. I've bought belts from tsc, auto parts stores, get them from a cub supply, you'll be happy you did
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 08-25-2012, 08:38 AM
Sugarmaker's Avatar
Rdrnek,
Welcome.
These guys will have you mowing in short order.
CUB brand belts do seem to hold up well and I have stayed with that brand too. May be a little more expensive but they do work.
I think when you get the turn buckle fixed and a new button you might be goo.
Haven't looked at one of these in a few days and cant remember about where the springs are/ But a test would be to watch the system as you depress the center and it should spring back forward when you let off . if this is not happening then you may have other issues. So did the clutch system work just a little while ago then quit working all of a sudden?
Regards,
Chros
Casbohm Maple and Honey
www.mapleandhoney.com
Old 08-25-2012, 11:42 AM
red56turbo's Avatar
The belts from CC are designed for all the odd turns and twists caused by the mule drive configuration. Just trying to save ya some green in the long run. The CC belts are initially more expensive, but in the end pay for themselves.
Josh
Diesel Cub Cadets...........
Old 08-25-2012, 02:23 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default Belts
I am currently using the NAPA Blade Runner- P/N 6513BR- (Mule Drive Belt) with good success. At 19.99, the Napa belt will save you about 7 bucks.
I have tried generic belts from TSC before, but they have not lasted long on that mule drive.
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 08-30-2012, 10:12 AM
Rdrnek Rdrnek is offline
Well I got my parts yesterday I was hoping you guys could take a look at this PTO thrust button and let me know if it's the right one for my 149. I am sure the fiber button I got is right but I'm not so sure about this one.[IMG][/IMG]
Thanks,
Bob
Old 08-30-2012, 10:26 AM
after I read your post I tried pushing in on it and it did not budge in or out. I just don't understand it because when I first got it it worked. here's a picture let me know what you think
[IMG][/IMG]
Old 08-30-2012, 10:32 AM
Rdrnek,
Welcome.
Regards,
Chros
Yes Chris the clutch worked until I replace the belt and then it just stopped working. And now even without a belt on it will not disengage.
I also just wanted to say I stumbled onto a really great forum here I really appreciate all of your help
Old 08-30-2012, 12:41 PM
TommyK's Avatar
Thanks,
Bob
Sorry Bob, that's the wrong thrust button. That's for a pto type B with brake. The one on your pto looks ok to use.
Old 08-30-2012, 12:53 PM
TommyK's Avatar
[IMG][/IMG]
Bob, I was wrong, there is a single spring on your pto. Did you get a new turnbuckle? Can you adjust it now?
