Old 07-19-2012, 11:47 AM
ljones's Avatar
ljones ljones is offline
Originally Posted by tgwilie View Post
A 1450 K321 won't work in a 149, different PTO's don't cha know.
It will still work, you will have put in a switch, and change the wireing a little. MANY people have done this.
Old 07-22-2012, 03:24 AM
tgwilie tgwilie is offline
Oh I think it's a little more complicated than that. The guy is asking for some help so why not give him a step by step?
Old 08-01-2012, 10:47 AM
bfingar bfingar is offline
Smile
I believe I finally found the problem with my 149-20 minutes into a run, it would sputter like it was running out of fuel for a minute or two and then run mostly normal the rest of the run. I looked at the fuel delivery, the carb, the ignition.
I believe my battery was causing the whole sputtering deal about 20 minutes into a run. I do not know if I had an occasional short in the battery that limited the battery voltage and as a result pulled hard on the generator or what. All I know is that I change the battery and the issue has gone away for the two mowings since I replaced the battery.
