Old 07-15-2012, 10:30 PM
Looks like it is time to change the fluid and filter, or check the charge pump rotor for breakage or a broken pin...but being that it moved when you first had it running I would change the fluid and filter.
My thoughts, too. If it has been sitting for a long period of time, then a blockage can enter the filter and strange things have been known to happen with filters. Change both the fluid and filter, since it will need to be done anyway and see what happens!
Old 07-15-2012, 10:34 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Talked with Vince O tonight, he said the relief valve is stuck. I'll attempt to pull it out tomorrow and try his recommendation. All the roll pins are in good shape and the fluid looks clean as a whistle. With some luck it will be a relatively easy fix.
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 07-15-2012, 10:43 PM
Jack that rearend up and make sure that it is very stable if you run it and try to unstick that valve!!! I had a stuck valve once on a 129 and I had it jacked up, but not as stable as I should have. When it released, it took off on me and ran into my garage--right over everything and only stopped when the snow blower on my 149 held it back. I should have been safer in my work and got very lucky--just trying to keep you from repeating my stupid mistake!
Old 07-15-2012, 10:54 PM
EarlJ's Avatar
I hate to say it, but I believe had I been there when that happened I would have been rolling on the floor laughing. I will take a page from your book and make sure its up on stands before I give it the gas.
