Old 06-19-2012, 07:55 AM
PaulS's Avatar
PaulS PaulS is offline
Now you all have my interest peaked. I will go up to my sons house and look at my 102s to see what rock shaft is there and that should give an idea of what that lever does.
Old 06-20-2012, 04:13 PM
jcsmith jcsmith is offline
Default lever
I think CADplans has it right. Hand operated clutch/brake mod by owner? May be missing his/her left leg. Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-20-2012, 04:23 PM
PaulS's Avatar
I was thinking the same thing that a PO may have to operate the clutch/brake by hand.
Old 06-20-2012, 07:12 PM
PaulS's Avatar
I looked at my 102s and that lever definitely is hooked to the rock shaft that operates the clutch/brake and it turns when operating the foot lever on the opposite side and there is no cut out on the foot rest so it is a PO mod. I would assume to hand operate the clutch/brake for whatever reason.
Old 06-21-2012, 03:02 AM
lonnyb's Avatar
lonnyb lonnyb is offline
Looks like a home made parking break.
Notice the curved tooth looking thing and the flat pice of iron welded to the handle.
Simple but effective parking break, if that is what it was intended for.
However the parking break should have been on the cluth/break pedal side of the tractor.
