Old 06-19-2013, 10:41 PM
Originally Posted by maddog784 View Post
I used 1/2" x 7 bolts on my 23x10.50s. Logic would tell me that another 1 1/2" would do the trick. Any cub with internal brake should take them on the inside, or you can stack them on the outside - just get longer bolts.
EDIT: I used carriage bolts - makes it a whole lot easier to install. If you are doing inside and outside, I guess all-thread would be the way to go.
So basically to run this set up youd need 1/2 by 9" carriage bolts?
Old 06-19-2013, 10:59 PM
I have 75lbs. weights on mine, and just use two bolts. The weights will stay centered in the rim. I suggest bolting the inside one to the rim, and the outside weight to the inside one with shorter bolts in the two holes you didn't use. That way you can take one set off if you want. Also, that way, you don't have to fight twice as much weight when getting them lined up and bolted on.
Note: I didn't want to fight a loose bolt, so I welded a nut to the inside of my rim. Then, I just hold the weight in place with my knee and thread a long bolt in from the outside. Cordless impact and done!
Old 06-20-2013, 12:18 AM
bolivier's Avatar
bolivier bolivier is offline
I like his idea!!
Old 06-20-2013, 09:05 PM
So, on a 147 rear wheel mounting on the outside an IH weight would require how long of a bolt?
Old 06-20-2013, 09:23 PM
IH bolts...
5" 6-12
6" 8.50
7" 10.50
your mileage may vary
Up to 530 and counting...
Old 06-21-2013, 06:41 AM
Grampie Grampie is offline
Oh My! How hard is it to stick a tape measure through the bolt hole on the weight and into the bolt hole on the rim then add an inch for the washer & nut? What about the thickness of the 2nd wt? Add
Old 06-21-2013, 08:52 AM
IH bolts...
5" 6-12
6" 8.50
7" 10.50
THANK YOU this was all I was trying to figure out when I asked how long I needed one. Since my tape measure won't fit through the weight hole.......
