Old 04-12-2012, 10:28 AM
cubs-n-bxrs's Avatar
Could you show pics of the hydro end. Does the hydro end leak like a faucet? I would be lead to believe that welding that end would melt the seal in that end cap. Some people just shouldn't be allowed to play with welders.
Old 04-12-2012, 11:50 AM
sgt.porter's Avatar
sgt.porter sgt.porter is offline
Yeah it's hard to convey just what I mean without pics, but it'll be 7 1/2 hrs before I get home from work to take pics.
The shaft isn't welded to the hydro. There is a flex disk joint at the hydro end. The weld I mentioned is at the "T" at the end of the shaft. That 1x4 (or so) plate that bolts to the flex disk is welded to the end of the shaft. What I want to do is make 2 more of these plates, cut a piece of the shaft out of the hub end, weld these plates to each end of the gap and mount a flex disk there at the hub..
In my mind, doing so would eliminate the need for the pin and slot in the hub, but I dunno. Anyone here make their own drive shaft?
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck
1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them.
Old 04-12-2012, 01:17 PM
Ash_129 Ash_129 is offline
Originally Posted by sgt.porter View Post
Have a link for parts? I don't know anything about anything, but the mount for the flex joint on the hydro end of the shaft is welded on, so I figured a new flex joint would need welded as well.
Check out these posts. VVV
http://www.onlycubcadets.net/forum/s...ht=drive+shaft
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
