I am guessing, this is just a minor issue. Something vibrated loose on the way to it's new home.
I just think that whole day was bad, with all the problems I was having. I should have stayed in bed.
I pulled the battery out, took off the ground wire, going to relocat that to back on the frame. I checked the connections they all seem to be good, but I'm going to check each connection as I clean it. That way I'll know it is good. I'll see if I can find the safety switch and check it. This may take me a while,I post the results. It has me befuddled, because it ran great when we loaded it on the trailer. I think it was just a bad day, everything was going wrong. That is except for getting a new cub. ole 147 Quote:
Congrats! |
Well I checked every wire, cleaned terminals, changed the battery, found the safety switch, witch I wonder if it could have been placed in a more hard to get at location maybe but I doubt it.
Couldn't get the plug off to it. So I wonder what's the secret to get that booger off? Other than 4 oz. of C4. I tugged pulled wiggled for a good while but it ain't moving. |
Sounds like it may be a bit corroded up in there. Just keep tugging. If by chance you break the plug, you can use female spade connectors to replace it.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Got it off!
Waste of time. ![]() Made jumper wire still no go. ![]() I wonder if it is the ignition switch. I dont have a meter so How would I check that? ![]() I'm bout ready to put it up for sale or strip it for parts.... |
If I were to give up everytime something goes south, I'd have no tractors. Suck it up, and find the trouble.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Well said, Todd!
Hang in there David! You will get it!
Is it dead with no clicking at all??? do the lights come on?? do you have a 12v bulb you can wire up for a voltage check cause that battery is good...any fuses behind the battery??? jump the selonoid.... process of elimination....you will get it Dave...
