Cam gear cover comes off next
![]() Breather cover is next ![]() breather has a few layers ![]() Breather parts laid out on workbench ![]() Camshaft comes out next. The pin holding the cam needs drived to flywheel side ![]() Make sure you remove and keep the shim(s) from the flywheel side of the camshaft. ![]() The tapets are next to be removed. I mark the tapets with the letter E(exhaust) and I(intake) so I reinstall them in the same spot. ![]() Next is the valves and valve springs. I used this tool to remove the springs ![]() Valve spring compress ![]() |
Points push rod should pull out of the block. This one didn't. Had to push it towards the center of the block. End of push rod was mushroom. Needs replaced.
![]() Only thing left is governor gear. ![]() Remove the screw under the governor arm ![]() Make sure you remove shims and bushing ![]() I like to tag and bag as I remove parts. ![]() Most interresting thing is the K301 marking in the block ![]() |
Merk
Looks fantastic! Thankyou for the documentation. At some point I would like to muster a little courage and try my k161 rebuild, not for a while though. ![]()
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
I like to check the crankshaft and cylinder bore before it goes to the machine shop. Here is the main tools I need to use:
Micrometers and bore gage ![]() Kohker service manual ![]() Sheet from Kohler to record before and after measurements ![]() First thing I like to check is the crankpin for wear. I check crankpin in 6 places. They are the flywheel side, center and the pto side. ![]() I measure 90 degrees to the first measurement. ![]() New crank journal measurement is 1.500/1.4995 Max out of round is .0005 Max wear limit is 1.499 Max taper is .001 5 out of the 6 measurements were 1.500. One was 1.4995. Crank is good. |
Thans for the pics, Dale! I've been following your progress on the engine.
The cylinder bore is next. I like to check the cylinder bore in 6 places.....top middle and bottom of the bore. Them I measure the bore 90 degrees from the first measurement.
First measurement: ![]() 90 degrees to first measureemnt: ![]() Sometimes it is easier to check the bottom of the cylinder bore by measuring the bore from the bottom side: ![]() My gages are old school. I have to use a snap gage in the clylinder bore to get actual distance. Them I will use the correct micrometer to get the actual measurement: ![]() Bore specs for a K241 are 3.2515/3.2505 max wear is 3.254 Max out of round is .003 Max taper is .001 Measurements were: top inline with crank: 3.253 middle inline with crank: 3.254 bottom inline with crank: 3.253 top 90 degree-crank: 3.2525 middle 90 degree-crank: 3.255 bottom 90 degree-crank: 3.252 Bore is out of spec in the middle of the cylinder. Motor needs bored .010. All the measurements were recorded and a copy will be given to owner when he picks up the motor. |
I double check my measurements with this gage:
![]() Using gage: ![]() I will keep using old school gages. They are easier to set up. |
A huge thankyou to Only Cub Cadets and my friend Dale. You guys are
Allen, If you would like to move the thread to a more infoumative/ tec. topic your more than welcome. I cannot describe how happy I am to share a learning experience with my friends at Only Cub Cadet and Dale.
Just a big thankyou Only Cub Cadet.net! ![]()
now I know where to go for engine work, if needed.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
