Old 12-26-2011, 08:24 PM
thenrie's Avatar
thenrie thenrie is offline
Yeah. A three-point with a hitch adapter would be the way to go, but this 682 is going to end up with a backhoe on the back and a bucket on the front, so I'm not going to spend the money for a three-point for it. It would have to be a manual lift anyway, because the 682 doesn't have hydraulics. I expect I'll just be careful and not try to use the 682 to move my horse trailer around. Then again, looks like I could run a steel strap, maybe a 1"X3/16", from the frame, where a three-point would attach, to the back of the upright part of the hitch mount and bolt it in place. That would remove the leverage completely and move the stress to the frame. Then it would simply be a matter of watching the tongue weight.
Tony
Stafford, VA
1650, 682...
Old 12-28-2011, 11:33 AM
maddog784's Avatar
That would definately help to keep stress off the bottom half of the transaxle. Perfect points to use in the frame, too!
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 12-28-2011, 10:05 PM
weaverama weaverama is offline
Originally Posted by thenrie View Post
Somebody on the other Cub forum suggested I add reinforcement on the ball hitch mount to add support from the frame or axle, so I won't pull bolts out of the rear and/or bend the rear plate on the trans. He said the way the hitch is mounted will put a lot of leverage on the hitch plate and could cause damage if a trailer with too heavy a tongue weight were hitched up. I have seen tube hitches made for the Cub hitch plate, so I figured my setup was fine, but I can see where the ball hitch mount configuration could put some real stress on the mounting bolts on the hitch plate. I don't plan on moving anything terribly heavy, but I have a 16' landscaper trailer (GW 7500#) and a two-horse trailer I might move around the yard either unloaded or lightly loaded.
That could have been one of my posts showing my stupidity at setting a loaded Boy Scout cargo trailer down on my hitch without checking the tongue weight first. Fortunately it just bent the hitch and didn't rip the bolts out of the aluminum rear on my Super. First bit of advice, check the tongue weight no matter where you mount the ball. Second bit of advice........Cub brakes will not stop a loaded trailer (or boat) once it gets rolling down hill. You and the Cub become fairly insignificant in the stoppage equation. Don't ask me how I know.
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 01-03-2012, 08:10 AM
thenrie's Avatar
Hehe. I can imagine. That's probably a story you can chuckle about now, but was no funny thing while it was happening!
So, last weekend, I installed new (used, of course) exhaust manifolds and muffler and a new hydro fan on the driveshaft. Also installed new spark plugs.
My manual says .025 on the spark gap, but that sure seems narrow. The plugs I pulled out were actually in great shape, probably recently changed out by the PO. The gap was about .035, which is about how they come out of the box, and it was running fine. I set the new plugs at .025, but I'm not noticing any difference. Any thoughts on point gap for the KT17 Series 1?
Tony
Stafford, VA
1650, 682...
Old 01-03-2012, 08:28 AM
Start your point gap at 0.018 to 0.020.
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 01-06-2012, 08:14 PM
thenrie's Avatar
Thanks.
I just had my first disappointment with the 682. Since I have fixed all the little issues I found, I decided it was time to drive it around a bit to warm it up and change the trans fluid and the engine oil. When it came to changing the engine oil....Argh!!! I can't get the plug out!!! I ended up using my 1/2" drive ratchet and just stripped the corners off the bolt head. Why in the heck would somebody tighten an oil plug that tight???!!! My next move is to try biting it with a pair of vice grips and see if I can remove it. If that fails, I'll just pump out the oil and change it that way until I get a chance to try to drill it and remove it with an ez-out.
As far as the trans, it was about 2 quarts low, but it looks pretty good inside. There was some gummy stuff where moisture had gathered a little, but not bad. Not like some of the pics I've seen posted. Filled it to the check hole with Hy-Tran. Good to go.
Tony
Stafford, VA
1650, 682...
Old 01-07-2012, 08:11 PM
thenrie's Avatar
Just a friendly reminder to everybody who does their own servicing. HAND TIGHT ON THE TRANS FILTER!!!!!! NO NEED TO USE A FILTER WRENCH TO TIGHTEN IT!!!!!!!!!!
Don't ask how that came up.
Tony
Stafford, VA
1650, 682...
