Old 12-09-2011, 02:04 PM
bogey68's Avatar
bogey68 bogey68 is offline
Well I found out I was running lean. I put a fuel bowel on her a while back. It wasn't letting enough fuel in the carb. So I put a different one on and now its running great..thanks for you help
Old 12-09-2011, 02:23 PM
cub123's Avatar
cub123 cub123 is offline
Glad you found the problem, at least it was a simple fix
Old 12-09-2011, 05:00 PM
Well said!
Old 12-09-2011, 08:35 PM
ksmith's Avatar
ksmith ksmith is offline
Thanks for all the replys. I fixed it today... I stopped at a Cub dealer and picked up a set of points on the way to the shop this morning, and it worked!
Everything is good to go. Installing some decals tomorrow, loading, and it'll leave for Nebraska Sunday afternoon.
Kurt
Old 12-09-2011, 08:40 PM
I agree It sounds like a lean mixture condition but other possible solutions
You may have a exhaust valve sticking ( slow to return ) , my 9n ford is notorious for it and does the same thing you talked of , if it even has compression to run
old fuel will do this every time and you might have a burnt exh. valve by now or a loose guide
I see you are in MI possible carb icing ? it happens in seconds
128
Old 12-09-2011, 09:04 PM
Kurt
Hey am glad you got it fixed. I would have been all over the carb and fuel delivery due to a lean condition making the exhaust hot. What made you decide on points? I'm just trying to keep ideas that work in my little black Cub book.
Old 12-09-2011, 10:48 PM
Great news, Kurt!
Old 12-11-2011, 08:53 PM
chris chris is offline
Default exhaust
i would say you have a exhaust valve problem check the clearance and reseat it lap it with valve gringing compound,
Chris Westfall - Cub Cadet Classics
