Old 11-29-2011, 10:31 PM
Congrats on the 682, Tony!
Old 11-29-2011, 10:36 PM
We want pictures!!!
I am sure you will find a good used muffler out there in cyberspace.
Old 11-30-2011, 11:31 AM
thenrie's Avatar
thenrie thenrie is offline
Got to drive it a little last night. Trans works fine, PTO works, deck looks good and works, Carlysle ags in good shape on the rear, 5-ribs on the front, sheet metal and paint are all in good shape, no rust apparent on the frame or sheet metal, the rims are still white, even the wiring looks to be in good shape.
The engine starts right up, although the starter bendix is weak and sometimes doesn't engage. The carb, however is a mess. I have to work with the choke to keep the engine running, and when the throttle hits a certain spot, the engine takes off and over-revs. I'm surprised the PO didn't blow the engine. Once it over-revs for a few seconds (while I'm frantically trying to get it back under control) it starts sputtering and backfireing, like the valves are sticking, probably getting a little overheated.
I have already ordered a carb overhaul kit, a tune-up kit, manuals on CD, new hytran for the trans, and put a bid on a muffler on ebay.
It smokes a very little at startup, not unusual for flatheads, but no noticeable smoke while running. I think a tune-up, carb overhaul, and an oil change should give me a smooth running machine. A muffler will make the wife happier. It's the early KT17, so I plan to use Mobil 1 or another good synthetic oil and hopefully get a few more years out of it before I have to overhaul.
Pics coming on Friday!
Tony
Stafford, VA
1650, 682...
Old 11-30-2011, 10:22 PM
72-149's Avatar
72-149 72-149 is offline
No need to
its not dead & i dont beat my 149 !!?? ...lol
Old 12-02-2011, 07:24 PM
thenrie's Avatar
Here are the pics I promised. Sorry about the quality. Morning sun was coming through the trees, so I was going to move it to a better spot, but wouldn't you know it, the starter wouldn't engage. Guess I'll be taking that apart and freshening it up as well. You can see my faithful helper there in the pics also.
I was wrong about the 5-rib fronts. They are just the original stock tires. Getting sort of cracked and old-looking. Probably about time for a new set...
Tony
Stafford, VA
1650, 682...
Old 12-02-2011, 10:32 PM
Tony that looks great! Thanks for the pics!
Old 12-02-2011, 10:50 PM
Nice 682, Tony! Appreciate you showing us your pics.
Old 12-03-2011, 06:18 PM
Oakley782's Avatar
Oakley782 Oakley782 is offline
I have never seen that style air cleaner on a series I, it does not have the plastic oil filler, i would look at the speck number on the engine. 24302 would be a series II
Luke
1979 682, 1981 782,
Old 12-03-2011, 06:55 PM
Only the very early Series I engines did not use that air filter. Series II air cleaners say "Series II" on them. Between that and the oil fill plug, that's a Series I.
Old 12-03-2011, 11:35 PM
thenrie's Avatar
Yeah. I was aware of that, but figured I'd go for it anyway. If I could have found a 782 or a 782D I would have preferred it, but I needed a mower. This will fill the bill very well.
I have been fighting off the urge to start modifying it. Thoughts of adding hydraulics, front, rear ports, deck lift, Cat 0 three point...you know how it is. Cheaper to just save my pennies and buy a 982D!
Tony
Stafford, VA
1650, 682...
