Old 11-29-2011, 09:47 AM
Pictures would be the most helpful.....
Old 11-29-2011, 10:24 AM
cub123's Avatar
cub123 cub123 is offline
The only way a 23 8.50 12 will rub on the inner fender is #1. Wrong rims or #2. The rims are on backwards. Pictures will be very helpful. Are your valvestems on the inside or outside of your rim?
Old 11-29-2011, 12:37 PM
CarBiz's Avatar
CarBiz CarBiz is offline
Nope valve stems are on the outside. I went and ordered a pair of wheels from Rich @ Patton the more i looked at it. I think you hit the nail on the head cub123 wrong wheel. I will get some pics for you guys though before i get the new ones on!!
Old 11-29-2011, 04:14 PM
I was going to recommend bungees also, but Matt beat me to it. Now, the handy man's secret weapon....humm...I wouldn't duct tape if I had new tires unless you like cleaning the residue off. I would probably use the zip ties instead.
You tape the chain to the rest of the chains, not to the tire. It hasn't done anything to the tire in the years I've been doing that.
Old 11-30-2011, 09:13 AM
CarBiz's Avatar
here are the pics
Old 11-30-2011, 09:19 AM
I am going to say wrong wheels. They look to be offset the wrong direction, meaning too much wheel in towards the frame. I may be wrong tho. Lets see what some of the other guys say.
Old 11-30-2011, 09:21 AM
CC1650Dave's Avatar
yeah, you can see that the PO even bent the fender pan to get these wheels in there. Your tractor's probably going to have several inches of wider stance once you get the right wheels on there.
Old 11-30-2011, 11:25 AM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
Definitely looks to be other then stock wheel, but before you go investing $$$ into a new set, I would make sure how much you need to go and still clear a mower deck. In the end it will be your choice between different rims or spacing out your present ones.
My over sized/nonstock ones cleared ok but not if I wanted chains on them. So I went with a half inch out on both sides and still cleared my deck with out having to remove the spacers.
Just trying to throw out options.
Old 11-30-2011, 01:55 PM
CarBiz's Avatar
No prob thanks for the insight like i said i did call and am getting some correct rims from Patton.
Old 11-30-2011, 02:01 PM
cub123's Avatar
Yep, they are the wrong rims for sure, as mentioned the right rims will make it much wider and much more stable.
