Old 11-09-2011, 10:39 PM
polaris_13 polaris_13 is offline
yeah it hasnt been cold enough for that here yet we have been in the 60's the last 3 days and 40's at night but i did notice condensation inside the trans when i removed the shifter. like i said the clutch was shot but it still moved around in all gears hi and low range and now it acts as if its all in neutral
Old 11-10-2011, 06:40 AM
In that case you need to check for a sheared spirol pin between the driveshaft and transmission input shaft.
Old 11-11-2011, 12:22 AM
10-4 hopefully ill have some time this weekend to tear it back apart and take a look
Old 11-14-2011, 11:04 PM
if im looking at what i think im supposed to be looking at it looks like it isnt sheared, if were talking about where the driveshaft connects into the front of the transmission that roll pin is still in there. what does the creeper lever connect to inside the trans? is it possible something isnt connected in there because the lever feels like it just flops back and forth. id kinda like to have an idea of whats supposed to be going on in there before i tear into it
Old 11-14-2011, 11:22 PM
ihnick's Avatar
ihnick ihnick is offline
my old 100 did the same your talking about. i cant remember how exactly it looked but there was a tiny roll pin inside the creeper that made the lever engage the creeper that was broke. so basically with that pin broke, only the lever would move and nothing else. all you got to do is take the creeper off and you should see it inside there if its broken. just my experience speaking.
Nick.
Old 11-14-2011, 11:34 PM
awsome, at least i dont sound crazy anymore haha ill have to tear into it. taking off the creeper means splitting the tractor in half correct? or is there a top panel i can remove to service it or something?
Old 11-15-2011, 12:32 AM
You'll have to split it and on NF's no cover to take off they are spot welded into place.
Old 11-15-2011, 12:50 AM
do i have to tear all my tin off or can i get to it from underneath?
Old 11-15-2011, 06:43 AM
"It looks like it isn't sheared"...that doesn't mean anything. All the pieces would probably stay in there and it would look normal.
Old 11-15-2011, 08:48 AM
Do you have the service manual? We have one in the tech section of the site but I would suggest getting a hard copy from Binder Books. They are a site sponser and it's a lot cheaper then printing it out.
