Old 10-13-2011, 08:48 PM
A spirol pin holds #25 to #9. You may also have a PTO safety switch plate pinned to #9 also. It will be inside the tower. To get to it with ease would probably mean removing the steering wheel and pulling the tower off of the frame.
Old 10-16-2011, 11:24 AM
Abeach6882 Abeach6882 is offline
Can somebody tell me how to disconnect the drive shaft? I'm not sure if its held on by set screws or just pins that can be tapped out.
Old 10-16-2011, 11:32 AM
It should be held in by 1/4" spirol pins. Use some PB Blaster and soak the pins and drive them out.
Have you downloaded the service manual for your 106 yet?
Old 10-16-2011, 12:08 PM
Yeah I've downloaded a couple manuals. Thanks again for the quick response.
