What? No backlash from any purists.....then it's up to me!
WHAT HAVE YOU DONE? HOLY COW.....YOU TOTALLY CHANGED THAT BEAUTIFUL WORK OF ART INTO A HYBRID WHATCHAMACALLIT!!! HOW DARE YOU MONKEY WITH THAT NICE LOOKING CUB!!! ![]() ![]() Nice Job on that install.......Hope that provides you years of service and all the compliments that a great job at engineering deserves!! ![]() Cub Cadet 123
I'm a purist type and I like it! I can respect the hard workk that goes into custom projects!
It was a fun project .... nothing was cut or bent to fit so with about 3-4 hrs time the original K series could be droped back in without to much hassel.
With the 28 lbs/ft of torque this engine generates it pulls like no tomorrow. B. |
I relaly like this set up. Nice job!
Aaron '83 782 #723927 ****original KT series 1 engine ****added dual hydraulics from older, donor 782 '04 SRC621 '95 Magnum (M18S) spare engine ****spec 24646 ****s/n 2507913316 |
I realize that and enjoyed the razing ! Mearly mentioned to others that this could be done without hacking up the frame etc.
cheeres to youBryan |
I think your repowered cub looks great, good work! I am considering making a tractor out of a hodge podge of different models and repowering it. I bought a 6.5 hp motor at harbor freight for the boys go kart, it is a predator brand engine, well they also have a 13 hp complete with electric start for less than $350...I am sure you could catch it on sale for much less than that. I am really impressed with one I put on the go kart, but really haven't compared the 13 to a kohler to see if it is feasible or not. The owners manual for the 6.5 also has all the specs for the 13, all I would need to do is measure/ compare it to a kohler. The predator engines are not a Honda clone, but are very similar to a Honda, the go kart should be a good test for it's durability.
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
Looks good. Did you hard mount it or keep the iso's?
I'm not fat, I'm just fluffy |
tubbyfirefighter , its hard mounted to bottm of frame rail flanges, needed to raise it 1.25 inches to have the drive shaft level and also to allow the oil filter to clear the frame rail. Even tho its hard mounted its very smooth due to the v-twin design.
B. |
looking at this.....i have to wonder if there's much difference in the room in a 1250, 1450 wide frame and a 149. it looks like with a little work this could be done to a 149 too. i don't ave a 1250, or a 1450 to compare to my 149, so i would welcome comment. nice swap. looks excellent. no sin there. bet you use less fuel, run smoother, and have tons more torque.
