I also use rimguard. It's about 50 bucks to have 10.5's filled here.
Murphycc - thanks for the explanation!!
Diz Jr. thanks a bunch for the pics man!! Now another question...I just fill them up until they "look" full then put the valve stem cap on? |
papaglide,
I roll the tire around till the valve stem is at 12:00. Remove the valve core and hook the adapter up and start filling. I fill mine just till the fluid is at the valve stem with it at 12:00 That leaves a little air space at the top to still allow the tire to flex and cushion the ride. Thats whats nice about the air release button on the adapter. You just shut off your pump and push the air release. A steady stream of fluid will come out when you get it full to that point. I always have to drain a little back out. I never seem to check it just at the right time.:biggrin2.gif: This is the way i find works best. I have tried just breaking down one side of the tire and just dump the fluid in, and had trouble with a couple of leaks around the bead. Guess i didnt get it cleaned enough. |
Let's not forget why it's best to put your fluid of choice in tubes...
Thanks Diz. Nice explanations and pics. THAT'S what I'm talkin' about!!! Visuals help my simple mind comprehend stuff!!!
Glad to help papaglide.
I forgot to mention that after filling i run 12 to 15 lbs. air pressure. And like Matt G. said the tubes help avoid any mishaps. I have tubes in one of my tractors, the rest are tubeless. I make sure to check the air pressure every so often to keep them sealed up tight. |
Here is another question, is this something I can do to my turf tires and have a noticeable effect? Or should I just wait until I buy ags and fill those?
Diz Jr.,
Great pictures and advice on how to get her done. |
It looks like Northern Tool has a similar drill pump on sale now for $9.99
http://www.northerntool.com/webapp/w...le&cm_ite=pump |
I like your avatar, Red Green is my idle.
