Old 08-26-2011, 05:59 AM
Vince_o Vince_o is offline
Couple of things
1 you need that splash gasket in the carb, if I remember right both used the same type of gasket.
2 nothing wrong with the walbro carb, except that there is no high speed adjustment, and YOU HAVE to get the spring set right on the float
3 someone said that if both carbs are dong it, look else where, I agree with that statement
4 run a filter on you fel line. Briggs make a nice small filter that will fit behind the air filter housing. Dale told me about them years ago and I use them on all my stuff.
5 be sure you have the float set right. And Id use the carter carb
Old 08-26-2011, 09:05 AM
73cubby 73cubby is offline
Default Spring
Vince mentions a spring on the float. I don't ever recall seeing a spring on mine.
Thanks for all the help
Old 08-26-2011, 02:29 PM
The walbro carbs typically have a tiny little spring that connects the needle to the float, IIRC.
Old 08-28-2011, 10:50 AM
ab147's Avatar
ab147 ab147 is offline
green 4 acres
you mentioned boiling fuel, I had a cub do that after replacing the fuel line, The line would get hot from the head after using it for awhile and the tractor would die, then be fine after things cooled down.after rerouting it everything worked fine.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
Old 08-29-2011, 09:31 AM
Default Fuel Line
Originally Posted by ab147 View Post
green 4 acres
Green Acres,
It is ironic that you mention the fuel line. This morning I was thinking about this. I seem to think that when I did the rebuild, that hose was replaced and it was not a fuel hose. Therefore, I am going to replace it.
Thanks for all the support.
darrell
