Old 08-08-2011, 04:31 PM
Bathtub Bathtub is offline
Default 1450 PTO blows fuse
After about 45 minutes of mowing using the 44A mowing deck on my 1450 the 10A PTO fuse blows. I've tried both slow-blow and standard fuses. I've adjusted the belt tension correctly, set the PTO air gaps to spec, and checked the wiring. All OK. I find that if I let the tractor sit and cool off and replace the fuse the PTO works fine untill the next time. Anyone had this problem and know the fix? I'm ready to buy stock in Buss Fuse.
Tags
1450, fuse, pto
