Old 10-01-2011, 12:33 AM
johncub7172's Avatar
Default Got'em!
I have went ahead and purchased the 100. Came with a very well built cart for 250$.
Old 10-01-2011, 06:33 AM
Congrats John on the 100!!
We want pictures!!
Old 10-01-2011, 09:10 AM
Congrats John!
Old 10-01-2011, 09:16 AM
juniors1282's Avatar
Good deal. Your gonna love it!!
1966 IH cub cadet 102x2
Old 10-01-2011, 10:51 PM
Glad you got the 100, John!
Old 10-02-2011, 07:47 AM
scleve scleve is offline
Congrats on the 100, you'll love it.
O _____ O 27670 O 38245 O 49448 100 _____
All W/Fenders, 3 Point, Lights, Brinly Adapter
124 ______ 106 ______ 107 _______ 127 _______
All W/Hydro, 3 Point, Lights, Brinly Adapter
108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter
109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext
2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect...
Old 10-02-2011, 11:48 PM
Boy, I sure do love this one! I need to remove the front axel now to grind some welds and paint. I was using a punch-pin and tapping the coiled spring pin with a small ball-peen hammer and was not making too much progress when I noticed the coiled spring pin becoming "mushroomed". I stopped there because I didnot want to be getting crazy with hitting this too hard. I just want to do all these repairs "text-book", the right way! So I'am thinking if I take my cut-off wheel and zip off that side of the coiled spring pin, it should come out. Then I can start the refurb on the front axel as well.
Old 10-03-2011, 12:10 AM
Default front axel,left steering knuckle
Here is my next challange. The PO never botherd to replace the grease zerk on this side of the front axel. So, it became very stiff and hard to turn the steering wheel. So much so, That I believe it put alot of stress on my steering assembly. The left steering knuckle is bent, as in you can notice my L-tire sitting in toward the frame of the tractor. The steering arm that connects to this steering knuckle is in very bad shape as well, having being bent beyond the point of repair. I figure I need a new or replacement left side steering knuckle and steering arm. The parts I have extra: both sets have been drilled out to a 5/16" hole for a plane bolt, nut to serve instead of the required coil spring pin connecting the drag link. This tractor I will be taking my time with and only using IH Cub Cadet parts, or if necessary, the next best I can get. The right side steering knuckle looks A-1! Next challange is the steering assembly refurb, and I'am thinking of going with the IH Cub Cadet steering up-grade kit: has 1 precicion steel shim, a NICE/GBC thrust bearing and nylon locknut. $ 24.00 from Cub Cadet Specialties. What do you think of this steering up-grade, those of you who done it? So on to the research on how to correctly remove the steering wheel. Then on to rebuilding the clutch with all new parts from Chris W. Then the motor work, my needed creeper gear, and the IH #1 tiller restore. Whew! What a long winded post. But that is my game plan, with some Cub Cadet paint along the way.
Old 10-03-2011, 11:59 AM
Looking forward to your progress, John.
Old 10-03-2011, 01:00 PM
Thanks Allen! This will be sorta a slow go. More rain/wet weather today. I did manage toget the 100 back up onto the operating platform. I'am thinking tri-rib front tires now.
