Old 07-25-2009, 11:53 PM
aagitch's Avatar
aagitch aagitch is offline
That looks really good. Make sure you post a pic of it put back together.
Old 08-05-2009, 07:01 PM
deputyrpa's Avatar
deputyrpa deputyrpa is offline
So....in between various other tasks, I got around to the re-assembly of the hydraulic cylinder a few days ago.
First, I installed the head's O-ring and seal
Then I lubricated them with hydro fluid and carefully fit the rod through.
Then I placed the piston in a cushioned vise, being careful to allow for rod clearance. I applied blue loc-tite to the rod threads, and screwed the rod in as tight as I could get it without dislodging the piston from the vise. Again, I used a large screwdriver in the rod eye for leverage. Excess loc-tite was wiped off, and the unit was checked for absolute cleanliness.
I installed the lubricated piston O-ring.
Continued in next post........
Old 08-05-2009, 08:06 PM
deputyrpa's Avatar
Then I dipped the piston into hydro fluid and CAREFULLY eased the piston into the case. There are two grooves at the head entrance where the head seal and retaining wire are fit, and the fine sanding and polishing I did previously was to make sure the edges were smooth in order to allow for smooth passage.
Then I installed the head seal and fit the head on.
I placed the case in my small pipe vise and fed the retaining wire through the window as I turned the head with a spammer wrench. The wire supplied in the kit has ends that were mushroomed from being cut with a snipper, so I filed them smooth, and under-beveled the end I used to push through, so it would not dig in to the head groove.
Finally installed the ugly, unpainted fittings, leaving the lock nuts loose for alignment after attachment to the 982.
Fortunately, I had re-assembled the engine earlier, and a quick test revealed smooth operation and no leakdown.
Piece of cake! Thanks for the help!:biggrin2.gif:
Old 10-18-2009, 07:25 PM
Mountain Heritage's Avatar
Excellent play by play!! VERY helpful! So where did you get the seal kit from ?? Order it online or get it from a dealer??
Old 10-18-2009, 08:59 PM
Nice work deputyrpa
I have rebuilt bigger cylinders but never tackeled one that small.
Thanks for the great pictures and explanation
Old 10-19-2009, 09:42 AM
Roblynn's Avatar
Roblynn Roblynn is offline
Great lesson, deputyrpa!
I have done larger cylinders also but have never seen the "wire" retainer! What a great job!
It's so nice out.....I think I will leave it out!
