![]() -Mark 1978 1450 1976 1450 |
![]() Quote:
The oil shower is very normal if you pull out a dipstick on most any single/twin engine while running. It is not a sign of a problem. Blow by is usually represented by lots of oil vapor/smoke out of the crankcase breather tube while running |
If that coil from your '57 Chevy wasn't the internal resistor type, and you didn't connect one externally, you're going to burn up those new points in a hurry.
Thank you, George and Matt. I'm not sure if I agree with you, George. While I'm not expecting a vacuum like you'd find on a PCV-equipped car, this is definitely excessive. My Snapper Yard Cruiser with a well-used (but well-cared for) ten year-old Briggs doesn't do anything close to what the K301 does. However, your response made me consider that perhaps the location of the dipstick being so low and short might contribute to the oil shower. All of my other engines, both vertical and horizontal shaft, have a much longer dipstick tube. Will I still get an oil shower after this engine is freshly rebuilt?
The Chevy coil doesn't have an internal resistor, Matt, but my goal was to just move it a few hundred feet off of my lawn to my shed, and I had reinstalled the old Kohler points due to some issues with the bracket for the Chevy points. Your point (unintended pun...) is well-taken, though. Thanks again. |
