Jimmy,
I would swap out the rear. Find a cast one and swap out the alum. rear. |
Too much work.
I went over to Partstree.com. There I looked up the parts list for #2 tiller. There was a kit to attach the #2 to a three point hitch. Neither CC or Partstree list it or the parts as available. As I scrolled down to the bottom, there convienently, was a list of the tractors the #2 attached to; 1000,1200, 1250, 1450, 1650, and 800. I wish I had done this before. It would probably be easy to find one of those tractors. Thanks again.
Too much work? Come on...you could do it in an afternoon. All you have to do is remove the frame cover and fenders, put jackstands under the footrest supports, disconnect the driveshaft, brakes, and hydro linkage, unbolt the rear, roll it out, and then reverse the process to put the new rear in. Nothing to it.
