Old 06-13-2011, 01:37 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
That's how they are. I'm out of ideas at this point...
Old 06-13-2011, 11:57 PM
MOturkE's Avatar
MOturkE MOturkE is offline
Just shooting in the dark here, but... Are you certain that the left blade is turning properly? It's possible it's sticking without any belt squeal. Another option would be to rotate the left blade just a bit further around than it is now, it might be that the grass is being blown underneath the left blade by the center blade and it's not standing up when the cutting edge comes by. Like I said, just a couple of shots in the dark... hopefully, they're not blanks.
Old 06-15-2011, 04:44 AM
cdlong's Avatar
cdlong cdlong is offline
My 50 was doing just as you say. Blade was loose. Didn't feel loose, but when I put a 1/2" breaker bar on the nut, it was loose. Had to use my foot to hold the blade to get it tight.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 06-17-2011, 04:43 PM
Peruvian Peruvian is offline
I agree to check the drive belt tension and the blade nut. Sounds like something is not spinning fast enough.
