Hadn't seen the previous post. 3000 hrs !!! Still I wouldn't throw money into it without some sort of NDI on that block. I have gone this route before and it just doesn't pay to zero one out.
Yeah if that's a Series II with no block damage you'd save a fortune just doing a freshening up of that engine. It'll last many more years.
Hello, I'm back with good News,
been a long Time not here, but now, i've a little Time to tell you some new about my Cub Engine, It was yery difficult to get the Parts for it, but i got them finally in Summer, i got new Undersize Rods, Undersize Main Bearings, Piston Rings, Gasket Set, and a Fuel Pump. A used Cylinder, with Piston i got from Scott,(thanks). My Engine Rebuilder grinds the Crank on 0.10 Undersize, made Valve Service, and grinds the Cylinder Bore clean, after i assembled the Engine,/without Heads), he grind the Valve Stems for the right Play. Last Week in August, i moved the Engine in the Cub, and try to start, and after the first cranks, broke the Starter. After assemble a new Starter, the Engine starts, and runs good, but not right, i think, at last, i made a Carb Service, spend new Breakers, Sparks, and Condenser, adjust the Carb, and now the Cub runs yery good, don't smoke, and have good Power. mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!! |
more Pics.
Great to see you back, Georg! Glad you got your 782 going. Thanks for the pics.
That engine is definitely worth saving over putting a vanguard or something else in it.
