Old 05-30-2011, 04:18 PM
johncub7172's Avatar
If the holes are not prefectly clean, you stand the risk of stripping out the set screws as well as the scocket. Soak with PB, use a .30cal. boar brush on a drillmotor and clean them out. As a matter of fact, I let each hole soak for 3 days, since I was in no super need of it.
Old 05-30-2011, 09:11 PM
lwrehm lwrehm is offline
I'm in the same hell here. Got one of the 3 sets of screws out but the other 2 are giving me fits! Thankfully I had to stop and start up the Big Green Egg just about the time my temper was getting to me...and the fumes from the burning PB Blaster. Waited for it to cool down a bit turned it til one of the holes was verticle and filled it PB. Try again in a day or so, I have plenty of time as this is my new-to-me engine that I will be rebuilding this summer.
I did get some good seat time today, my 4 y/o and I drove thru town pulling a trailer full of brush to the village brush pile, the whole ride we both were grinning ear to ear!
Old 03-01-2013, 07:24 PM
jboehm jboehm is offline
I am now in the same position. Stripped set screws. What is the deal with using the puller? Won't it pull the bearing and locking collar off as well?
Old 03-01-2013, 08:04 PM
Yes it will.You will have to remove the thrust button and the fingers to use a puller, basically you have to bend the fingers back and destroy them in the process.I just took one off and they used locktite on the 3 bottom screws.
Old 03-02-2013, 12:25 AM
FFGino FFGino is offline
Default I hate my PTO!
GUYS!! FYI, the set screws are hardened. IF you decide to try to drill them, use a carbide bit (read expensive) and use a lower speed than a 1/4 in. drill runs at. If you can find a small enough diameter cement/concrete drill, with patience this may work but the carbide used to make this type of drill is INFERIOR to a true carbide drill. Using normal drill bits will quickly empty your pocketbooks, frustrate the h**l out of you, and not do much to remove the set screws.
Just my 2 cents. This is from a retired tool maker.
Happy Cubbing!!
FFGino.
Old 03-02-2013, 09:56 AM
jbrewer's Avatar
jbrewer jbrewer is offline
So when the guy used the Red Wrench on the set screw, did he "de-harden" them which allowed him to drill out the piece?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-04-2013, 04:35 PM
In orger to "de-harden" the set screws, which are in by the end of the crankshaft, he would have had to heat the ENTIRE
PTO, bearing and the end of the crankshaft, cherry red and then draw down the temperature very slowly...no I don't believe so.
Happy Cubbing!!
FFGino.
Old 03-04-2013, 05:10 PM
PaulS's Avatar
PaulS PaulS is offline
Why on earth would someone use thread locker on those particular screws. I presume that is why they doubled up on screws.
Old 03-10-2013, 12:16 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
The other day I was trying to remove a broken bolt on my 1922 Southbend lathe. Went to drill the bolt so I could use a easy out and I got lucky. The drill bit just screwed the bolt right thru the part.
So I decided to buy a set of left hand drill bits to keep with the easy out set. It may just save me some work. Maybe it will back out a broken bolt or stuck set screw.
