Old 09-27-2009, 01:29 PM
greg r greg r is offline
Thanks so much, this is the "field" experience I'm look'in fer. Sam, you're spot on on the knock.
As a matter of fact, I did notice the cam oscillating back and forth a tad as I rotated the crank and it seemed loose on it's pin. The bore's measurements where close to wear limit, and the crankpin dimensions where just within book tolerance at .0005" and running clearance on the rod was checked with Plasti-gage as per the Kohler manual, but I also used an inside gage on the rod. Altogether with a loose exhaust valve in it's guide, a loose cam, and a scratched piston; and from what everyone is posting here, I going for a full rebuild and NO balance gears.
What about balancing the rotating assembly? I'm familiar with multi-cylinder engines, I'm thinking it would be all the more helpful on a single.
