Old 05-29-2012, 03:01 PM
I've got the steering wheel in the PBblaster marinade now, in prep for doing the steering fix. I'm looking forward to getting that done as there's quite a bit of free play in there! Didn't stop me from using the O today on my last day of freedom before going back to busting rocks for a living. :-)
There's lots of rough edges but it's a reliable little runner now...
A good reliable runner is about all we can ask for John.
Old 05-29-2012, 11:06 PM
That's so true!
Old 06-10-2012, 01:21 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default One more little repair
The O had a completely frozen by rust throttle assy when I got it, and I don't know if the one that was on there was original, but I salvaged and cleaned the lever assembly. Following some of Dukes advice, I purchased a cheap ( $3 ~ ) throttle at the local AgriSupply. I ditched the lever part and was able to swap out and resize the cable.
One thing I discovered, is that the diameter of the outer spring assy is smaller than the one that was on the tractor, so the clamp at the carb end wouldnt cinch down enough (it's always something!) . A piece of heat shrink tubing made a good neat fix for that, and I'm good to go.
The governor assy is a bit of a mystery but I'll figure that out next time. For now, it's nice to have reasonable throttle control again. By the way, a small dremel cut off wheel is Da Stuff for shortening the outer spring housing.
It's a little fix, but one of many. (the therapeutic Zen of Cub repairs)
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-10-2012, 06:46 PM
Good job on the throttle, John!
Old 06-11-2012, 10:58 AM
Looking good John!
Old 06-11-2012, 11:49 AM
jbrewer's Avatar
The careful reader would notice that in perfect John form, I've cleverly installed the cable backwards, requiring a rework right after this photo
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 06-11-2012, 11:50 AM
John your a hard man to keep up with!
Old 06-11-2012, 12:26 PM
He sure is.
Old 06-11-2012, 02:38 PM
jbrewer's Avatar
If there's a 50/50 chance, 90% of the time I'll be wrong.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 06-11-2012, 02:46 PM
John
