Old 03-20-2017, 07:56 PM
tinkerman tinkerman is offline
Well if the pictures post you'll know what I mean. All the kings horses and all the kings men said "hey we know this hillbilly from Tennessee and he can fix you up humpty" well it's still not 100% . Clutch problem kinda "fixed itself" still hanging up here and there. I'm gonna give it a little time. Got an oil leak. Only when it's running, in front. But doesn't appear to be front seal. Ran great first couple laps around the yard then wanted to start surging. Adjusted on the carb a little but didn't help. Didn't notice any wobble in the throttle shaft when I rebuilt the carb. But after it heated up it had a lot. Steering is like new. Zero play. Gotta get that dang nut on the steering wheel. Pop the clutch and your holding it in you hand
..... unattached lol. Pulled it back in the building for now as it's storming like crazy right now. The pictures look better than the actual tractor but I'm tickled with it and I know Austin would be too. As soon as I get it running right I'm gonna drive it up to the lady's house that Austin got it from and show her. We told her the day he bought it that we were gonna restore it and would be by
Old 03-20-2017, 08:12 PM
Cubfan79dad Cubfan79dad is offline
Looks awesone man!!
Old 03-20-2017, 09:05 PM
ccguy's Avatar
ccguy ccguy is offline
What a beautiful 102! I've never seen an original seat in such good condition either. Outstanding work!
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 03-20-2017, 09:14 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Looks amazing! Great job!
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
Old 03-20-2017, 09:47 PM
Thanks guys..... now the bad - adjusted carb back to initial settings per the manual and it doesn't wanna start now. When I choke it then open the choke it hits but no start. Like I said earlier the throttle shaft seems to have a lot of play.
(1/16th or so probably) I used the cheap plug that came with rebuild kit, gonna replace that. Also didn't put in new points. Gonna do that. I used the best looking of the two sets I had. Plug wire I bought is toooo long and lays on the heat shield. Gonna pick up a shorter one. When I rebuilt the carb, I didn't soak in carb cleaner . Just used the spray stuff. Ok I know, .... I skimped on the external stuff a little and shouldn't have. But I'll get it!! Any advice?
Old 03-20-2017, 09:50 PM
john hall's Avatar
Excellent work, and that goes for both of you. Although it didn't go as planned, you can say both of you did fine work on the tear down and rebuild. There is a lot to be said for properly labeling and storing parts so things can be put back together. I'm glad to see you got it finished and did an excellent job.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-20-2017, 10:39 PM
Bamafan Bamafan is offline
Inactive Member
Anything can be fixed and healed with time and effort. Beautiful job.
Congrats
[B]Larry[/B]
Old 03-20-2017, 11:13 PM
DieselDoctor's Avatar
Very nice job. One to be proud of and a wonderful tribute to your son's memory.
Old 03-21-2017, 12:28 AM
johncub7172's Avatar
Thumbs up
Wow! Very nice job!
Old 03-21-2017, 05:01 AM
Dirty Steve's Avatar
Looks wonderful! I'll bet you'll have the kinks worked out in no time at all.
