Old 12-09-2012, 06:32 PM
Sam Mac Sam Mac is online now
Chip
You could get fancy and make a rectangular exhaust to exit between the slats on the grill. Just my 2 cents but that is what I would do after all you have put into it. At least it would keep the grill clean. This Bud's for you.
Old 12-09-2012, 07:52 PM
cub149's Avatar
cub149 cub149 is offline
Nice work on the grille, Chip! That's a neat cub!
Thanks Allen
Chip looks like it's time for another visit so I can test it out for ya!
You're more then welcome, of course I owe you a couple of visits. I'd like to see what all you have going on.
Chip
That's a good idea I hadn't really thought of. I think I'll see how this works out first. I'm about burned out on working on it. I really want to paint it but need to wait for the funds to build up. It'll look so much better with a paint job. I did hit the front of the frame with some yellow, got tired of seeing the bare steel.
Chip T.
Drexel NC
Old 12-09-2012, 08:47 PM
[QUOTE=cub149;163816]
I'm about burned out on working on it. QUOTE]
Man do I know that feeling!
I'm about tractored out, getting like a job. Sitting here with a Chevis on the Rocks at the moment Buddy.
Old 12-10-2012, 12:33 PM
cub123's Avatar
cub123 cub123 is offline
Originally Posted by cub149 View Post
I made a grille yesterday for the front. I used a piece of bar gratting. Cut the angle on the sides to match the front opening and welded on side pieces to frame it in. I then welded two bolts to it that fit in the slot where the spring went on the original grille. I wanted a grille that the slats where closer together but couldn't come up with anything.
I decided to just let the exhaust blow straight throuh the grille since it is steel. I'll use some high temp paint on the grille. It seems a bit louder with the shortened exhaust pipe but not bad. I could cut a hole and stick the pipe out the front but I like the looks without. Is there any reason this would be a bad thing?
Boy that's a sharp looking tractor! I'm not trying to sidetrack you, but what color you going to paint it? Bet if you did the grille in silver and did red and white that would be awesome! Just a thought, looks great in yellow too!
Old 12-10-2012, 04:08 PM
Donovan M.'s Avatar
Thats a nice 1066, and your going good on your Super 189.
Donovan:
62' Original-fenders
Old 12-10-2012, 04:23 PM
cub123's Avatar
Lol, its just a pic I found. Just pointing out how much it would look like the bigger tractors
Old 12-10-2012, 06:30 PM
cub149's Avatar
The goal of this site is to help people, NOT make more work for them
Now I have another decision to make.
Just kidding
You are right, that would look cool. I knew the grille had that look but I didn't realize the resemblance until you pointed it out. I'm pretty sure I'll stay with the yellow, it's my favorite on the cubs, but I do like red.
Thanks for the kind words also.
Chip T.
Drexel NC
Old 12-10-2012, 06:36 PM
Yeah like that is going to happen, LMAO
Old 02-26-2014, 03:34 PM
chris hall's Avatar
chris hall chris hall is offline
I figured out the turning brakes and have it all installed. I had to lengthen the pedals, add a piece where the brake rods connect so I could put the return springs on. I was able to use the old brackets that where on there but had to change out the bushings, the ones on it had a lip on the outside of the bracket that took up to much room, so I welded on the bushings that came with the 2072 brakes.
In the diagram above, part #14, I was able to move it over to the right side and use it with the original linkage from the 1860. I tapped a hole and used a bolt to hold it in place to find the correct position for it. I will drill and pin it once I get the tractor running and can make final adjustments.
The power steering wasn't to bad. I used one out of a 2072. I was able to use the bracket that was with it. I cut part off the bracket off then heated, bent and drilled holes to match up with the mounting holes of the manual steering. I will have to shorten the steering column a few inches as it is way to long.
The third picture is of the original set up on the 1860.
It's getting there, but still a lot to do.
nice work i would like to one day change to caliper brake like those. btw i am in hickory nc
