Old 10-03-2011, 11:38 PM
You've been busy! Thanks for the update, Chris.
Old 10-04-2011, 01:38 PM
Sugarmaker's Avatar
Default some shots of the 14 hp, Kohler K321, 147R
Allan and folks,
Some cell phone pictures taken on my way out this morning. Clarity is not great but gives you the idea of the current status. So far it seems to be going OK.
What do you guys think of the color combo? I still have time to paint it all IH red but probably will leave the block flat black. Then on to the wiring, seat, dash assembly, engine installation, does it end?
Going to try to leave off the gas tank and top tins to allow the head to be re-torqued after running fo a while. (I am assuming it will run some day)
FYI The top dipstick is a shorty and just for adding oil. The real dip stick enters through the cam gear cover. It is a knurled knob with a o-ring on the shank, about 6 inch long stem.
I need the little rubber grommet for the point cover wire to pass through.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-04-2011, 01:45 PM
TheSaturnV's Avatar
Purdy!
Old 10-04-2011, 01:47 PM
Excellent pics, Chris! Looks awesome!
Old 10-04-2011, 01:49 PM
Sugarmaker's Avatar
Talking
Originally Posted by TheSaturnV View Post
Purdy!
That's a summary statement! Included a shot of what we would normally expect to see on a nice Kohler refurb! Consider the fact that I am not normal!
Regards,
Chris
Old 10-04-2011, 03:17 PM
CC1650Dave's Avatar
What was that about soaking the head gasket in water? I don't recall reading anything about that (?)
Old 10-04-2011, 09:18 PM
LarryW's Avatar
LarryW LarryW is offline
Looking good! I bet you cant wait to rub that paint off those pulleys!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-04-2011, 09:28 PM
LarryW's Avatar
.......Going to try to leave off the gas tank and top tins to allow the head to be re-torqued after running fo a while............FYI The top dipstick is a shorty and just for adding oil. The real dip stick enters through the cam gear cover. It is a knurled knob with a o-ring on the shank, about 6 inch long stem.............
Personally I would still use the top tins just for cooling reasons. That might be more important on a fresh engine? I guess see what the pro's do.
My 147 has that same oil dipstick configuration.
Cub Cadet 1811
Old 10-04-2011, 11:11 PM
That was valid 30 years ago, but not anymore. Modern head gaskets are not to be soaked.
Old 10-04-2011, 11:39 PM
westofb's Avatar
westofb westofb is offline
Chris,
Motor looks great with the red tins, I kind of like the contrast with the flat black block...looking good, keep up the good work!
Jeff
Brookfield, MO
________________
