Old 03-21-2023, 08:53 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
Located the hard to find "Diesel Throttle-Off" emblem.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 04-29-2023, 08:37 PM
1711Cub's Avatar
Smile
I finally got around to doing the cooling system maintenance on this machine. I flushed all of the old coolant out, replaced the thermostat, t-stat gasket, upper hose, and bypass hose with new OEM Kubota parts. The lower hose appears to have been replaced much more recently than the age of the tractor. I filled it with 50/50 green antifreeze/coolant. I ran it for 25 mins and it never got above 185.
Old 04-30-2023, 08:39 AM
Looks great 17!
I have a 2 questions.
1 -- Is that upper hose from the Kubota RTV?
2 -- What is this bracket on your machine? Either mine are missing, yours was added or Cub changed it in production.
Old 04-30-2023, 04:12 PM
1711Cub's Avatar
Thumbs up
The hose is indeed for a Kubota RTV. It is EXACT to the original except the large end, which is easily cut off. I paid $15 for it. Not bad for OEM Kubota.
The bracket is an add on that a previous owner added in an effort to ensure the radiator is supported. I've never seen it on any other Diesel GT.
Old 05-01-2023, 08:31 PM
1711Cub's Avatar
Wink
I finished up the upper hose with an authentic replacement insulation purchased in a 6' length from Home Despot. Fortunately, it was just over $10. The insulation was cut to mimic pics of original unrestored tractors. The ends have adhesive to seal it up. I glued this to the hose using 3M black weatherstrip cement.
Old 05-02-2023, 07:43 AM
zilla24's Avatar
zilla24 zilla24 is offline
Great work! Do you have a part number for the Kubota RTV hose?
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 05-02-2023, 08:08 AM
1711Cub's Avatar
Lightbulb
Thank you!
K7311-85150
Old 05-23-2023, 09:26 AM
1711Cub's Avatar
Lightbulb
I adjusted the valves. None were within the factory specification of .006" Some were too tight, and the rest loose. This was an easy procedure once getting the engine to TDC on cyl. 1. The adjustment is very touchy, so it took some finesse to get the .006" feeler gauge to fit snugly. The engine responded well, but it is still choppy at slow idle.
Old 05-23-2023, 04:20 PM
Farmall450's Avatar
Insulation looks great.
Old 05-24-2023, 08:21 AM
1711Cub's Avatar
Thumbs up
Thank you. On another forum, there were questions if the insulation would resist the heat radiated off the upper hose. Well, after a few workouts with the engine temp approaching 200F, and subsequent heat soak exceeding that, the insulation has not melted or distorted in any way. I think it is every bit as good if not better than the original material used Kubota/Cub Cadet. I will update further if something changes.
