Old 08-22-2010, 08:01 AM
Mountain Heritage's Avatar
Dumb question. How big is your resevoire for the oil? I am just trying to picture how much fluid you have/need to lift this. Correct me if I am wrong - you need the amount of what is in the filter, lines, pump, as well as enough to fully extend ALL the cylinders as well as have some left over in the resevoir? Rough figuring, what you said about 6 quarts - do you have enough it it? Is it possible the system is starved for oil still? I am grasping at straws here to be honest Matt, because from what you have explained so far - you did it all correct! Only other thing to try is to get rid of the restrictors within the lines to see if they are slowing it down too much? Is it possible it has some chunk of crap within the system that possibly got into it during reassembly after painting? Something as simple as a large flake of paint would screw the whole system up for flow of fluid wouldn't it? You have MUCH MORE patience with this than I would have Matt - I too would have been looking for the closest dynamite dealer!! Ya got me!??
Old 08-22-2010, 11:13 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Nice Work Matt!!!!
Could it be the filter itself or the Vent in the tank?
Old 08-22-2010, 06:43 PM
Fixed it! It turned out to be the relief valve on the control valve. It was set to basically zero. I set it to 800 psi, added some wheel weights, and now it's all set to go. Here's a couple of pictures.
I had to get the other two red ones out too...Left to right, 782, 682, 782D.
Time to find a place in the barn for it and store it until the snow flies...
Old 08-22-2010, 06:48 PM
Great pics, Matt! Glad you got it figured out.
Old 08-22-2010, 07:21 PM
jbollis's Avatar
jbollis jbollis is offline
Are planning to (PLOW) snow with it, or just move and pile it ? If you are planing to use it as a plow, you will be disappointed. Plowing with a loader sucks Unless it has float position, or you have an extremely flat driveway.
Looks good though. I will have to one sometime.
Sold everything but one.
Old 08-22-2010, 07:25 PM
I'll just move piles with it. I'll do the plowing with the 782.
Old 08-22-2010, 07:45 PM
TEET's Avatar
TEET TEET is offline
Great job Matt! It was nice following your progress :biggrin2.gif:
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 08-22-2010, 08:43 PM
Glad you got the problem solved and the loader done. Have you lifted anything with it yet?
Old 08-22-2010, 10:09 PM
johncub7172's Avatar
Smile
Holy smokes Matt! Good job getting it figured out! Here is my "other" tractor I run at my winter job. Now that is a fine looking line up!
Old 08-23-2010, 12:17 AM
ihnick's Avatar
ihnick ihnick is offline
i really want a loader and a 82series tractor now
Nick.
