Old 03-16-2013, 09:03 AM
Simple. take the adj stop off and save it for mowing.
If you lengthen your arm, it will add depth but limit up-travel.
?....does this type add on hyd lift have a float option??
Dave S.
Old 03-16-2013, 01:02 PM
Well I got the rest of the PO buggered up mods off the push blade today. And got it mounted on the 125, but....
Seems in the all the way down position it's about 1/2 inch from the ground, so do I need to make a longer lift rod, or am I missing something here?
The bracket that holds the ram and move it forward to the next set of holes. Next remove the height adjustment that bracket (I think that's the correct word) to allow the ram to go farther forward. If that doesn't work you'll have to make a new lift rod.
http://www.onlycubcadets.net/forum/s...ead.php?t=4616
Old 03-16-2013, 01:03 PM
Dave S.
Dave there is a float lockout on the NF hydraulic lifts but Todd is missing his and it's on order.
Old 03-16-2013, 08:59 PM
Well explained Duke, but a little late(I didn't turn the computer on till tonight)
I cut an extra lift rod I had and added an inch to it, seems good to go. What I did was looked up in the tec. section about using the 2x4 method.
Drove the tractor up on four 2x4's and lenthened the rod. Seems fine.
Seeing I was at it, I also put the rear wheel weights on and the tire chains, man was that a bear getting those chains on
I think it's now ready for whatever we throw at it.
Old 03-16-2013, 09:09 PM
Todd.
I would drill another hole above the hole where the lift rod is now.Normally you put the rod in the top hole but that is used for installing the bracket to the rockshaft arm.
Old 03-16-2013, 11:07 PM
Looking good, Todd!
Old 03-17-2013, 01:16 AM
Todd.
If you would Lew, then I will to, closer to the top hole or bottom, center?
Old 03-17-2013, 10:52 AM
A little late.
Old 03-17-2013, 11:00 AM
Todd,
If you go to the tech section and look at the blade and hydro lift install it tells you the size hole but not where it goes.But I would drill it closer to the top hole.
Old 03-18-2013, 12:55 AM
Todd,
OK Lew, will do.
Then I'll try my original lift rod back in it.
Thank you
