Old 12-01-2017, 12:38 PM
Chad126's Avatar
Chad126 Chad126 is offline
I need to get tubes in the rear tires first... that's something else I need to do. By the way, the one thing I did notice is that these little tractors don't have a very sharp turning radius.
Old 12-01-2017, 02:31 PM
Originally Posted by Chad126 View Post
Had some huge adjustments to make on the carb. Somehow the adjustment screws were all messed up. I guess at some point someone tried to adjust them. Anyway, I set the carburetor per the manual instructions, turned the ignition, and this sweet little thing runs like a top.
You don't get specific in your post, but I want to point out that the initial settings the manual recommends are not the final setting. You need to tune the carb for your engine. It will likely be close to the initial settings, but make sure you find the sweep spot for your engine. As a note, if you read the manual all the way through how to tune the carb, it states this.
No, the NF tractors don't have a very tight turning radius.
Old 12-01-2017, 03:23 PM
Chad126's Avatar
I did end up reading it all. I made the best adjustments I could after the initial settings, but I still think I could improve it some. I have a steep hill on my driveway and it seemed to bog down just a touch when I was driving it uphill. I remember the manual mentioning this but can't remember the adjustment. I'll look tonight and try to fine tune it. All in all, I am pretty pleased.
Cub Cadet put a lot of work into their manuals. I've got a Ford YT16 and the manual for it is basically useless, with the exception of a few spec callouts
Old 12-01-2017, 03:27 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Why tubes? I dont use a tube unless Im trying to save an old crappy tire, tubeless are alot easier to fill with fasher fluid.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 12-01-2017, 03:47 PM
Chad126's Avatar
I just don't want my wheels to rust out.
Old 12-01-2017, 04:42 PM
I prefer tubes with fluid filled tires. But I also prefer CaCl2. Whatever fluid you use, I agree, tubes are better, but not required.
Old 12-01-2017, 08:10 PM
Lanceskene's Avatar
Washer fluid wont rust the wheels, neither will rv anti freeze, you can also buy fluid from tire shops but its alot more pricey. Years ago farmers would use calcium, which is basically salt water, but that does rust out the wheels.
Filling tubes is a pita and then if you do have a flat you have no choice but to drain the fluid, pull the tube out of the tire and patch the tube, if its tubeless you can use a plug and be back to work in 5 minutes, Yes even with filled tires plugs do work. Each to their own.
Do you get snow? If not then you can use ag tires but those need chains in the winter, atv tires work well without chains.
Lance / Alberta Can
CCC 12.5 w/deck
Old 12-01-2017, 08:19 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Really looks good!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-04-2017, 12:31 PM
Chad126's Avatar
I see some good benefits with each option. as for now, I've got a leaky valve stem. I have AG tires on it now... Again, I'll try to get some pics up soon. sorry. Just have been busy. I do not hardly get snow, and when I do, I probably won't be getting this sweet little tractor out in it. I'll end up treating this tractor like a shed queen. I'll use the Ford to do most of the yard work, but will probably plow and might even try to find a tiller for it. Outside of a few runs a year, I'll probably just start it up a few times a month and ride it around the back yard. It was my grandfathers so Id like to keep it in good shape.
As always, thanks for the input.
Old 12-04-2017, 09:52 PM
Lanceskene's Avatar
Ooooh... what kind of Ford you got??
Lance / Alberta Can
CCC 12.5 w/deck
