Old 03-28-2015, 08:23 PM
cyr2872's Avatar
cyr2872 cyr2872 is offline
Oh and last but not least. Picked up some Tru Powers. All you guys on here posting pictures of yours sold me on them. Plus my property is a bit hilly and this tractor spins a bit in places, even with the added weight. My last tractor had Ag's and never spun. Looking forward to working with these guys!
- Jason
________________________________
1872 - Kohler 28hp EFI repower
Old 03-28-2015, 08:46 PM
jimbob200521's Avatar
You will fall in LOVE with those tires, great upgrade!
-Ryan
Old 03-28-2015, 10:40 PM
782CC 782CC is offline
Looking good. Chances are you will finish before I do. Work has gotten in my way. For my valve plate I added a standoff to set it out a little. Cleared the lever articulation better since that body is thinner. Word of caution. Where I placed the cylinder interferes with the battery. Going to raise my fender pan to clear.
The levers look good. I would have tapered to clear better except I was trying to look stock. Is the picture decieving? Levers look flat not 90deg.
Old 03-28-2015, 10:43 PM
Oh. Not welded up. Doh!
I want those tires....
Old 03-28-2015, 10:54 PM
cyr2872's Avatar
Yeah, welding isn't complete yet. I'll mock it up on the tractor to get the right angles I want to prevent clearance issues (haha, "right" angles.) I'll mark them and finish welding on Monday.
I planned on putting a garden in and the weather here is finally going to be nice enough next week so I need to get this baby back into working shape ASAP!
- Jason
Old 03-30-2015, 11:28 PM
cyr2872's Avatar
Ran into a bit of a snag when mounting the hydraulic cylinder. I found a deal on a 1811 lift cylinder that I thought I could make work. Turns out since I did the cast rear conversion I have even less room than with the aluminum rear. Also, the xtreme 3 point lift arm connection point is a lot lower than the one on 782CC's machine. This is going to be a little more tricky. Anybody have any idea's on alternative lift cylinders? One with a total diameter around 2" would make it a little easier (but with the same capability as the 1811 cylinder.)
- Jason
Old 03-31-2015, 12:30 AM
Just finished reading through this thread, great work don't know why I didn't see it before. But needed to give you a shout out on your project
Old 03-31-2015, 07:11 AM
These are pics I got from Aaron at Xtreme. Guess he had the same issue and this is his solution.
Old 03-31-2015, 04:16 PM
Berwil's Avatar
Berwil Berwil is offline
Your not going to find a smaller diameter cylinder with the same force. Fluid pressure is psi, if you multiply the psi x cylinder area (sq in) you get the force output of the cylinder. Smaller dia gives smaller force. The only way to make the force up is with longer stroke and longer lever arm on the input of the 3point hitch.
Bill
Old 03-31-2015, 11:11 PM
cyr2872's Avatar
Thanks Sam for the pictures of Aaron's machine. And thanks Bill on the fluid mechanics refresher.
I think I came up with a solution. I'm modifying the battery box so the battery is turned 90 degrees. This will allow me to notch out the battery box so that the cylinder is positioned somewhat like the way I have it in the prior post. I'll then weld extensions onto the cylinder lift so I can attach it to the 3 point. I'll then build a brace for the cylinder to attach to the frame. Should be plenty of room for the cylinder to fit in there.
I won't have the arms angled like in the picture. Just mocked up for now.
Also, some other fun improvements showed up today.
- Jason
