Old 09-25-2011, 12:38 AM
LarryW's Avatar
LarryW LarryW is offline
Cool! Lookin great!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-25-2011, 02:59 AM
Sweet pics Chris and $85 for machining cost is great!
Old 09-27-2011, 10:50 AM
thenrie's Avatar
thenrie thenrie is offline
On all those cables, try spraying some "PB Blaster" from just about any auto parts store. I know Autozone carries it. Spray it on, wait an hour or so, spray some more, wait, then start trying to move it. If that doesn't break it loose, you'll be far better off just buying new cables. I've had better luck with PB Blaster than anything else, including WD-40.
Tony
Stafford, VA
1650, 682...
Old 09-27-2011, 01:58 PM
Sugarmaker's Avatar
Default 147R engine build update
I will try to pry some pictures off the camera tonight.
Anyway, the current status is that the engine is coming together nicely!
- Head and block checked for flatness.
- Head plastic bead blasted.
- All gasket surfaces cleaned on block.
- New governer gear and cross shaft in place.
- Cam shaft re installed and checked end clerance.
- Main crank bearings cleaned oiled and in place.
- Crank installed and timed with Cam shaft gear.
- Bearing plate shimmed to allow .008 clearance end play on the crank.
- Piston rings checked for end gap right at .020.
- Rod marked and installed into piston on wrist pin and snap rings in place
- Rings installed on piston.
- Piston installed in block using ring compressor.
- Rod End cap aligned with oil hole towards cam shaft and torqure to 300 inch lb loosened and retorqued to 280 in/lb.
- Straub beer consumed to celebrate I did not take many pictures like Dave does!
Thinking of painting the block flat black high temp. What do you think?
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 09-27-2011, 02:14 PM
You've been busy Chris!
Old 09-27-2011, 05:49 PM
Sounds good, Chris! Looking forward to your pics.
Old 09-27-2011, 05:52 PM
westofb's Avatar
westofb westofb is offline
Regards,
Chris
Paint it red....they look bad a** red!!!!!!!!!!!!!!
Jeff
Brookfield, MO
________________
Old 09-28-2011, 11:08 PM
Sugarmaker's Avatar
Default some updates I owed you guys!
Jeff,
Check this out its going to be different!
Some shots as I assembled the K321 and the clutch assembly over the last few days. Sorry I just don't have time to work on cubs and load the pictures too
Hope this helps some one!
Engine is complete as far as all internals. Valves are adjusted. Oil seals are in place.
Yea Gracie had to get in on the action too!
I learned a lot on this engine. It has been about 15 years since I rebuilt a 10 Hp Kohler.
I learned some things not to do also! Like be very very careful when chasing the threads in the block for the head bolts! Stop when you feel the slights resistance! I cracked a fin on the block
Not sure what this will look like with red tins, and covers, on a slate gray block?
The compression release had me a little baffled for a minute or two.
I decided to remove the stock exhaust turn down pipe
Took a little hot wrench work to get it loose. I could put it back on later, but I think the exhaust will be a vertical, short, stainless, hand built stack coming off the head with 1 inch stainless pipe fittings.
Yes its getting to be more like the resto-mod that others have mentioned on their Cub projects.
Man I hope this thing will run.
I am getting a little punchy like Dave and need some support!
Regards,
Chris
Old 09-28-2011, 11:26 PM
Great pics, Chris! Thanks for sharing.
Old 09-28-2011, 11:35 PM
cub1450's Avatar
cub1450 cub1450 is offline
Chris your doing a great job keep up the good work.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
