Old 03-25-2011, 01:17 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Default Hood Supports
While piecing back together my 1250, I noticed the hood when shut left a huge gap in between it and the dash. I adjusted the lower cast iron grill back towards the dash. I also moved the dash tower the opposite direction and ended up with a 1/8" to 3/16" gap. There was just enough lip on the dash to catch the hood, but not support it properly. I decided to fab up a support using a 1/8" x 1 1/2" aluminum strip. Bent it up to fit the inside contour of the dash. Then I made 2 brackets that attach to the upper most bolt hole in the dash tower that will connect to the support. Sorry, I don't have pictures at the moment, but they will soon follow. Has anyone else made a support to help ease the load on the dash?
Nemesis
Old 03-25-2011, 01:25 PM
They had a support from the factory that had 4 rubber pads on it, two on the top and one on each side. The lip on the fiberglass dash is not supposed to be supporting it at all.
Old 03-25-2011, 01:30 PM
That part Matt G. was MIA when I purchased this machine. Just trying to fab something up with material I had laying around.
Nemesis
Old 03-25-2011, 05:57 PM
steve59's Avatar
steve59 steve59 is offline
Correction Matt, They actually made 2 different styles and one of them had only 2 rubber pads on the top and none on the sides and the other had no rubber pads at all. I have one of each but just installed the one with 2 pads a few months ago.
Chug a lug a luggin’ 5 miles an hour
On my International Harvester
Old 03-25-2011, 06:16 PM
I must have been thinking of the 1x8/9 one...I'm pretty sure those had four.
Old 03-26-2011, 09:15 AM
Thanks Guys for the information!
Nemesis
Old 03-26-2011, 11:43 AM
108cubber 108cubber is offline
Matt, my 108 has four.
KennyP
