Old 08-23-2010, 09:01 PM
Mountain Heritage's Avatar
So I got my gear box mounted on tonight while I was bbq'ing my chicken for supper. It went pretty good, next to no oil leaked out when I removed the bolts from the rear cover. I didn't take the time to hook the trailer to the hitch to see if the difference in the hitch being flipped over would be too low or not - I am pretty sure it will be fine.
Realized today while I was polking around the garage at lunch I had the correct size of rolled steel for the top pin so I slid it in and just need to see how long it needs to be cut off at. I am going to make the bottom part of my sleeve hitch deep enough that I don't have to remove the gear box to use the plow - hopefully I can get it strong enough that it won't bend!?
I think I will paint the rest of the hitch parts white the same as the frame work for the gearbox. Hmmmm..trip to IH dealer to get some paint!
Old 08-23-2010, 11:14 PM
Nice work, MH!
Old 03-15-2011, 06:29 PM
Thanks Allen.... I am trying!
http://www.gates.com/catalogs/file_d...tes%5Ccatalogs
Anyone care to take a shot at determining which "model" or "version" of belt I would use to hook this tiller up to my 982? I know I won't get one from Cub Cadet that will be the correct length. I am thinking the Super HC series would be good - but I am no belt expert! I am pretty sure I am going to get the tiller hooked up on the tractor so it raises and lowers correctly then load it onto the trailer and head for my Case IH dealer and have them fit a belt to it. Perhaps one off a combine will work - but if not, I was just wondering which would be a good one to try from Gates if needed? I am going to try to get one long belt to drive from front to back. I will install something like this mid-way through if I HAVE TO:
But I think if I can get away from this it will be much easier. One less thing to fabricate as well as something else to have hanging down from tractor that could catch something when not using the tractor. Too much of PIA to remove things all the time each spring and fall. Would rather just unhook the tiller and swap the mule drive and go back to mowing grass.
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
