I have a command 20 that I'm replacing the ignition modules on. The instructions say cylinder 1 should have the kill switch tab facing out, and cylinder 2 should have the tab in.
Cylinder 1 is the passenger side and cylinder 2 is the drivers side, correct? "Out" is the seat side and "in" is the engine side, correct? The modules really look omni directional. What could happen if they are mounted the wrong way? Thanks for ant responses. |
I could be wrong.... so verify.... #1 cylinder is the closest to the flywheel.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I just replaced the coils (ignition modules) on my CH18 Kohler engine. I ordered them as a set. Both coils were the same. The original coils that I replaced were set up for left and right. Did they make a mistake and send me 2 of the same coils? They were genuine Kohler coils...so I don't know...however they will work either way.
![]() I installed them with the left coil kill wire connector facing back and the right coil kill wire connector facing forward. So, the right coil appears to face in reverse. This allows the right plug wire to extend farther outwards to reach the spark plug more easily. I did have to move the wire harness to reach the connecting tab on the right side. The coils (modules) seem to work just fine.
