Hello everyone. I understand that the old IH Cub Cadets with hydro trannys cannot be rolled unless the engine is running. I know that modern lawn tractors/mowers with hydrostatic transmissions have an override pin at the rear. I have a Cub Cadet LT1042 that I’m working on right now. I pulled out the override pin as instructed but the tires go different directions, sort of like some driving vehicles. So it can’t really be pushed. I believe it to be from around the year 2010. Is this a problem or is it normal? I have little knowledge on hydrostatic transmissions so ANY advice or help is appreciated. Thank you!
Quote: If the rear end is jacked up, this is "normal" for the tires to rotate in an opposite direction.
They did go the opposite directions when I had it jacked up which is normal now I know. But they still go the opposite direction when it’s on the ground which doesn’t seem right as that makes it really hard to move still. |
The "pin" which you refer to in your first post operates a lever (bypass arm) located on the side of the transaxle.
When the bypass arm is operated it releases the hydro. I would check to see that the pin is securely connected to the bypass arm and that the bypass arm has full travel. (i.e. not restricted by crud, dirt, grass etc.) |
Thank you for the diagram Ironman!
