Old 09-26-2022, 07:26 PM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Looks like it's time to break out power washer for a little house cleaning in there while you are at it.
Check the front coupler while you are at it as well.
Exactly! I will do that before it goes back together. This 123 was not taken care of before I got it. What you're seeing is 40+ years of neglect.
Which coupler are you speaking of?? The other end of the drive shaft goes into the fitting on the output of the engine. At that end, the dowel pin is sheared off on one side.... I am going to get a new dowel to put it all back together.
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 09-26-2022, 08:02 PM
Use a center lock nut like they used when it was new.
Old 09-26-2022, 08:21 PM
nra1ifer's Avatar
Is that a nut with a nylon center?
nra1ifer
Old 09-26-2022, 08:39 PM
No, it has a dent in the side.
Old 09-26-2022, 08:41 PM
nra1ifer's Avatar
Lowes? Home Depot? TSC???
https://www.lowes.com/pd/Hillman-3-C...k-Nuts/3024732
nra1ifer
Old 09-26-2022, 09:14 PM
The coupler that the dowel pin through the driveshaft slips into.
I have seen them worn nearly 1/2 the way around through the coupling
Old 09-26-2022, 09:29 PM
nra1ifer's Avatar
Hmmmmm.... maybe mine is worn, and not a "detent" like I thought it was?
nra1ifer
Old 09-26-2022, 10:00 PM
Click on parts by Jeff on the top of the page, he makes those hubs an also the drive shaft.
Old 09-28-2022, 12:20 AM
nra1ifer's Avatar
Just realized: no cooling fan on that drive shaft.... I guess I need to order that, eventually.
nra1ifer
Old 10-08-2022, 06:17 PM
nra1ifer's Avatar
The 123 is going again! Glad to get it put back together! used it today to till an extremely dry garden spot.... we need rain!
nra1ifer
