CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 06-10-2019, 08:31 AM
Styphon Styphon is offline
Default White and blue/white wires
I have a 2015 xt1 gt54 mower. It was working normally then yesterday when starting it idles at a high rpm even with throttle all the way down. It also violently shakes during this. So I move the Tractor and find a connector with two wires, blue/white and white. I found an end missing wires on the right side near the pedal but can't find the other end to connect to.
Old 06-11-2019, 08:23 AM
ironman's Avatar
ironman ironman is offline
You "found a connector". Where did you find it? Was it laying on the ground? Was it hanging down from above?
Then you found an "end missing wires" What is an "end"?
Hard to help you when you make no sense, but most of the newer Cubs with an electric PTO use blue and white wires for the PTO connector. However that wouldn't explain your high rpm/running rough condition.
Old 06-11-2019, 09:28 AM
Welcome to OCC...........
I tried to find a wiring diagram for the XT1 and could not find one.
Roland Bedell
Buy: Made in the USA
Old 06-11-2019, 11:51 AM
When I moved the lawn mower I found it on the ground. It is two wires, the one end are exposed wire ends. I found a plastic connector to the right of the engine were these two wires fit. The other end is a white connector/plug with both wires feeding into it
Old 06-11-2019, 02:11 PM
cooperino's Avatar
Does your pto engage?
Old 06-11-2019, 02:57 PM
ironman's Avatar
So if I understand correctly, the connector you found on the ground plugs (fits) correctly into the one you found near the engine leaving you with two bare ended wires. If that is the case, inspect the electric PTO housing at the engine. There HAS to be wires coming out of it and connected to something. If there is keep looking, if not, it means something snagged those wires and ripped them out. But again, the PTO not working wouldn't affect engine performance.
Just curious, was the mower deck on the tractor when this all started. Is it on now?
Old 06-11-2019, 04:32 PM
Your description of the engine revving high with the throttle at idle is not a good sign.
Possible internal problems with the governor.....
Up to 530 and counting...
Old 06-12-2019, 08:47 AM
I found a Wiring Diagram. The WHT and BLU/WHT wires go the the Elec PTO.
Roland Bedell
Old 06-12-2019, 09:15 AM
ironman's Avatar
Roland, where did you find it? I searched quite a bit with no success. It might help others with an XT!.
Old 06-12-2019, 09:24 AM
I got it from a friend of mine.
Roland Bedell
