Old 08-04-2017, 07:31 PM
Default Must - cut - steel - !!
I just had to cut some steel,,, so I started,,,
A dozen pieces of 2" X 1/4" angle,,,
4 pieces of 1" round steel bar,,, 3 pieces of 1/4" flat,,,
What should I build??
Old 08-04-2017, 08:17 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I'll take a CADdrag!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-04-2017, 08:49 PM
Hmmm,, how do you locate parts accurately,, when the corners are not square?
CADDrag is a possibility,,,
PROGRESS!! 42 holes are drilled,,,
Old 08-04-2017, 09:47 PM
Mark centerline of work table at bottom.
Mark height and draw line/clamp piece at top. Mark center line on top.
Measure from top center to specific distance on bottom edge. ( if the part being fabricated is 42" wide, measure 21" off each side of centerline) Both sides should be the same measurement.
Old 08-04-2017, 10:22 PM
That is kinda what I did,, the parts turned out nice,,
more welding than I was expecting,, or was it because it was 90 degrees when I was welding??
At least the paint is drying nicely with the 90 degree heat!!
The old trailer ended up getting the over-spray,,,so I just finished the paint on the trailer,,,
Old 08-04-2017, 10:26 PM
CAD Plans picnic table. Love it
Old 08-05-2017, 07:38 AM
john hall's Avatar
A picnic table for 2, painted red--somebody is getting an early start on Valentines Day.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-05-2017, 08:19 AM
No flames? I'm a little disappointed.
Old 08-05-2017, 10:12 AM
Well,, the paint went on kinda thick,, and will take another day or two to harden,,
I ordered bolts from Amazon, they will be here in a day or two,,
I doubt the wind will blow this picnic table away!!??
I am planning on using the plastic decking wood,,
Do you think I will like that material?
Old 08-05-2017, 10:21 AM
You may need to add some support on the outside of the seat, you may find that the plastic decking is a bit flimsy where it's not supported.
