Old 09-03-2016, 06:14 PM
VIOLATOR VIOLATOR is offline
Default 1650 Hydro leak
Howdy all,
So it has been a long time since I have been on here. I have a few questions about the hydro on my cub cadet 1650. It has developed a leak on the hydro pump by the shaft that is coming out of the side. opposite of the speed controls. I have attached pictures. It started when I was going high speed for about 15-20 minuets. I was pulling a small trailer with my two buys in in.
Does anyone know if I have to split the pump open or can I just replace the seal with minimal disassembly. I looked for a thread on this but I was unable to find exactly what I was looking for.
I was also wondering if that seal is gone what other seals should I do while I'm in their.
My last question has to do with the tag on the pump. How would I identify this pump and what do all of the numbers mean.
Old 09-03-2016, 06:56 PM
The red circle is where the leak is coming from. So I have to split the case open in order to replace it. BOOOOOOOO. Are their any links on how to do this.
Old 09-03-2016, 08:49 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Looking at this picture you apparently have more to take care of unless my eyes trick me...
Gilles.
1963 100 (red)/in storage
Old 09-03-2016, 09:32 PM
You can replace the leaking seal without splitting the pump. You also should rebuild the trunnion area as OldSkull mentioned. That said as soon as you fix one leak others will follow. If it's leaking on one side it won't be long till it leaks on the other side. Life sucks, your tractor is old and it wants new seals and gaskets.
Old 09-03-2016, 10:04 PM
Replace the seal that is leaking, it is the easy one, no disassembly of the hydro needed.
If it ain't broke, don't fix it.
Do repair your trunnion, and, it would be nice if you had 2 release valves that were automatic, not just one.
Old 09-03-2016, 10:27 PM
That is great news to hear Yahoo. I am in the process of rebuild my relief valves and I was going to get new springs and get that fixed. I am also going to replace the fan and do a good cleaning. Thank you very much for the input. Ill be sure to put an update when I'm done.
Old 09-03-2016, 10:36 PM
OldSkull's Avatar
George your eyes are tricking you he got 2 automatic release valves, one look a bit "Rusty" that's all.....Oh well let it go and have a drink ...
Gilles.
Old 09-04-2016, 11:35 AM
Interesting obversation:
Post 1, picture 1 shows a nipple er button on a relief valve.
da udder fotos no nipples er buttons
Me thinks somebody tried to confuse me.
Sometimes I don't know if I'm cratchin' me watch or winding me arse
Old 09-04-2016, 03:10 PM
OldSkull's Avatar
You see nipple where there is none, maybe your level of testosterone is getting a bit high! No more blue pill for you!
Gilles.
Old 09-04-2016, 03:27 PM
Yep,
blue pills I use em, except they are Naproxen
But seriously, do you not see the manual button in the pix with the identification tag?
Something don't look right there?
