Old 08-10-2016, 12:22 PM
Bo185's Avatar
Bo185 Bo185 is offline
Originally Posted by ironman View Post
Hard to tell because of the crap on your relief valves but I think I can see a button. If there are buttons, they are manual valves. The crud may be holding the buttons down and that is why you can move it. If the buttons are up and you can move it you have bigger problems. Auto relief valves have no buttons.
The "hydrostat" spring you are referring to are called trunion springs. There are two that go in that square hole in the "trunion", which by the way is trashed. It can be fixed.
You got a lotta work ahead of you!
Yeah looks like the spring setup isn't in good shape.
Is the relief valves to two caps on top of the hydo unit? circled in red.
The are flat on top.
Old 08-10-2016, 12:48 PM
Terry C's Avatar
Terry C Terry C is offline
Those are auto valves. You don't need the lever shown in ironmans pics
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-10-2016, 10:42 PM
ironman's Avatar
ironman ironman is offline
If they are flat, they are auto release, if they have buttons like this they are manual. I wouldn't prefer one over the other unless you park your tractor on a steep hill and forget to set your parking brake. With the manual release valves the tractor will likely be where you left it parked. With the autos....... I'd look down yonder in the paw paw patch!
Old 08-10-2016, 10:50 PM
Terry C's Avatar
Looking at your pic again and your trunion springs are gone. I mean not there.
somebody put two bolts in it to get by. You've got some trunion work to do.
Terry
3225
Old 08-11-2016, 11:54 PM
Bo185's Avatar
Yeah I seen while reading up on them. Plan is to cut a new plate to weld on the arm and order new springs. I got a CnC plasma table so making a plate will take 2min. So shouldn't be that big a deal.
I got the front cleaned and painted.. I painted the motor as well. Also removed head to de-carbon it, looked like it been apart before had wrong spark plug as well.
I still have to pull the steering to fix it as well as the console. Hope to wrap whole thing up next week save for the deck. Might be a while on it as its missing parts and have to make others.
I'll get some picture of the progress tomorrow.
Old 08-12-2016, 11:29 AM
You've been busy! Looking forward to your pics.
Old 08-12-2016, 03:12 PM
Bo185's Avatar
Added some pictures. Spray painted the motor. The Head is just sitting on it waiting on a gasket. And yes that is a pipe 90* being used as exhaust its on there and owner was OK with using it.
It had wrong spark plug. Also the coil was a 6v coil and it was cracked so got the correct 12vcoil, need to check/replace points.
Waiting on powder to come in to finish the motor up as well as the sheet metal, so hope to wrap the rolling resto up next couple of weeks and give it back to the customer. Depends on how the deck restore goes.
Old 08-12-2016, 07:52 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Here you go
http://www.ebay.com/itm/Cub-Cadet-Dr...oAAOSwU-pXrQoK
Put a proper tunnel on there
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-12-2016, 08:03 PM
It had wrong spark plug. Also the coil was a 6v coil and it was cracked so got the correct 12v http://www.brphotrods.com/products/5...evy/index.html coil, need to check/replace points.
That link does not have the proper coil for your machine.... that's an LS motor swap to older cars site. So.... unless your putting an LS in that thing, I hope you didn't order a coil from them.
So Bo, what kind of shop do you run?
Interesting someone hired you to "restore" a Cub Cadet with such little knowledge about them.
Old 08-12-2016, 08:43 PM
Bo185's Avatar
Lol sorry was posting on another site and guess that link got left in that post when I edited it.
I own a business that does, CnC plasma coating, metal art, and powder coating. I worked as an FAA licensed A&P aircraft mechanic for 15 years before that. I been around IH's forever, just never tore into a cub before. I have a 1973 IH 1210 Travelette and a 1973 IH Scout II. The travelette is pulling my 55 chevy in the picture.
These are quite simple I have worked on 30 million dollar biz jets so a lawn tractor is pretty easy. I know the owner done work for him before on some of his other stuff namely LS stuff. But he got this in a inheritance from an uncle. I actually really like it so I may end up with it. If not then I might just look for one of my own.
