Old 05-16-2016, 10:07 PM
MattH's Avatar
MattH MattH is offline
Default Hydraulic issues
I finally got around to tilling the garden today, we have had rain for 3 weeks straight. Other than the dirt being more wet than I would have liked, the hydraulic (forward and reverse) of the tractor seemed to get worse and worse and I tilled the garden. By the time the sun went down it wouldn't even move in reverse u less it was pushed the tractor. Also to get the forward/reverse lever into the selected position is very hard. The lever is extremely stiff and hard to move. I'm going to check fluids tomorrow, but aside from that does anyone have any suggestions?
1450 Dual Stick Hydro | 42" Power Angle Blade | Model 1 Tiller | Homemade Wheel Weights
RZT 50
Old 05-16-2016, 10:39 PM
Sounds like the tension adjustment has tightened itself up a bit making it hard to move the lever.
The other issues, I suppose could be related, but I'd say pull your tunnel cover and have a look see at the linkage.
How long has it been since you changed the fluid and filter on the rear?
Old 05-16-2016, 10:57 PM
MattH's Avatar
I was wondering about maybe a linkage issue as well, thanks. I replaced the fluid and changed the filter last year. I finally got the rear cover sealed with RTV then I had to loosen a few boots to mount the tiller gearbox, ever since then it has leaked again. It doesn't leak much below the fill hole though.
RZT 50
Old 05-16-2016, 11:54 PM
Did the forward and reverse issue start after the fluid and filter change, or was it before, that's why you decided to change them?
Old 05-17-2016, 07:36 AM
MattH's Avatar
I've never had this issue. It just started yesterday while I was tilling my garden. It's so bad now, when I pull down for reverse the tractor just sits. It won't drive backwards in reverse. You can here the pump under a load, but the tractor just sits. Fluid/filter change was done during the 2015 Winter.
RZT 50
Old 05-17-2016, 09:47 AM
Just wondering if you're not out of fluid?
Old 05-17-2016, 11:09 AM
Dirty Steve's Avatar
Make sure you check you hydro linkages and Trunion springs.
Old 05-28-2016, 01:30 PM
MattH's Avatar
Alright, finally got around to take some pics for you guys. The trunnion looks like it has normal wear like many people have. Tell me what you guys think about it. It doesn't have run away like most people talk about. Also I forgot to mention that the adjustment knob fell off while I was tilling.. I wouldn't think this is related. I just adjusted the hydro to neutral and checked the hydro fluid, all is well. Drive lever is not stiff anymore but doesn't seem to have much reverse still.. I'll know more when I sink the tiller in some dirt today. Thanks.
RZT 50
Old 05-28-2016, 10:37 PM
MattH's Avatar
Tractor ran okay today, still not much reverse. I tilled for about 30-45 mins. When I was done, same issues.. Extremely hard drive lever and hardly no reverse at all. I had to push it in the shed (while in reverse). Any suggestions guys?
RZT 50
Old 05-29-2016, 12:35 AM
Berwil's Avatar
Berwil Berwil is offline
The springs are working their way out the bottom of the trunion, and the cam plate is leaning and barely contacting the springs. You need to repair the notches in the trunion and shim the cam plate so it contacts the springs in the center. There isn't a lot of lever movement for reverse, any trunion/cam plate slop will affect speed.
Bill
