I'm no wiring expert, so I'll leave that to others. The engine surging I'd start with flushing the fuel system and some fresh gas. Then go from there.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Next time I "check" a fuse I guess I'm going to get my meter out. It was the fuse. I had a spare 10amp one for the lights and sure enough it fixed the problems....except the surge. The manual says both my fuses should be 10amp so I guess that's what I'll keep in there.
I've never had a fuse look perfect but be bad, especially a slow blow without it being melted inside. Like I said before the last time it was surging it was a wiring issue at the voltage regulator, I was hoping that would be the case this time but those wires look good. I'll have to take a closer look at that area. Thanks for the help. |
This time the surging is something different so I'll have to figure it out. I did order a voltage regulator last night so maybe I'll get lucky. There must be something wrong with it if it's melting wires. |
Burnt wires and/or terminals are usually one of two things, or a combination thereof.
* Excessive Loads (High Amperage) * Poor Connections (Loose or High Resistance) I would be examining the situation once the new parts are installed.
| Tags |
| 982, pto, surging |
