Hey Guys, Before anyone points it out.. yes I have been to the Tractor Forum article on "How to rebuild your Onan engine" Yes it's fantastic and very helpful. However I'm stuck in the teardown process at a spot before the Article starts. If anyone could offer some tips or guidance it would be appreciated. I have the Onan out of the tractor finally! I have all of the shrouding completely off. I removed the rear screen and exposed the flywheel. I was able to remove the bolt that holds the flywheel into the Crankshaft but the flywheel it's self will not budge. I am not sure what to do and I don't want to force anything for fear of breaking something. Am I missing something here? Is there some secret bolt or pin holding it in I am not seeing? Also the front PTO will not come off. I have 2 stripped bolts holding it to the engine block. I'm picking up some stripped bolt removal tools tomorrow. However, I can't get the bolt that holds it to the Crankshaft to break loose. Is this a reverse thread or something? Whats the best way to break this seal so i can get the front PTO off and the flywheel off?
Javier~ 1980ish 982 w/ 3pt. & PTO /50C deck - a Work in progress. Brinly Moldboard Plow. I'm a complete noob at this so please take it easy on me.
you need a puller to remove the flywheel.
Also I know I will need a gear puller and that it has to be really heavy duty for this. are there any recommendations on a good affordable gear puller that will work for getting that timing gear off?
You can't get the PTO bolt in the crank to come loose? Are you using an air wrench? Just curious, what do you mean stripped bolt removal tools?
as for stripped bolt removers. I found these. I'm not sure they will work as the space to get in there is really tight. ![]() http://www.amazon.com/Craftsman-Bolt...d+bolt+remover
Regarding an air wrench, handy tool to have. For working on lawnmowers a cheap 1/2" drive tool and some 6 point impact sockets should be sufficient. I can't see dropping a ton of money on one just for working on a Cadet.
Elshiv, that is all good info that Dvogtvpe and John gave. I keep an electric impact wrench on my truck for work so if you don't have a compressor an electric one will work too.
Here is a cheap $15 harmonic balance puller that I use to pull flywheels. So far it has worked every time. DSC01991.jpg
Remove the bolt in the center of the PTO and the 3 nuts that hold the brake to the PTO (in yellow) and you should be able the get that nut off.
